Export sketch to DXF
I have a sketch created from a step model I would like to export as DXF to import it into KiCad. Trying to import into KiCad I'm getting the error message "No graphic items found in file to import".
I opened the file in LibreCad and saw that the dxf does not consist simple lines which are moveable, but a complex part which I cannot modify, just moving as complete (When I'm creating a simple multiline sketch, in LibreCad I can move the single lines around without moving the others). This might be the reason KiCad is not able to open it because it's to complex.
Do anybody know why FreeCad exports the part as one and not each line separated?
I deleted in a second sketch (Sketch001) the most of the sketch out, because otherwise it is quite slow.
It is the Flatpak version:
OS: Linux 5.4.8-arch1-1
Version: 0.18.14555 (Git shallow)
Branch: (HEAD detached at 0.18.4)
Python version: 2.7.15
Qt version: 5.12.5
Qt version: 5.12.5
- MBXL_RA_RCPT_2P24S2P.dxf
- Exported dxf
- (1.61 KiB) Downloaded 55 times
- MBXL_RA_RCPT_2P24S2P.FCStd
- (127.15 KiB) Downloaded 62 times
Re: Export sketch to DXF
Is this a bug?
i select the sketch, ctrl+e (export)
and... it works
and... it works
Yes I'm able to export, but when opening in LibreCad it's a single part, not multiple lines. I'm not able to import into KiCad
- wandererfan
Is this one any better? It seems to be individual lines in LibreCAD.
- mbxl_ra_rcpt.dxf
- (54.81 KiB) Downloaded 54 times
otherwise you can use the command "explode" in librecad to... explode a block
Hi wanderfan,wandererfan wrote: ↑Fri Jan 17, 2020 12:06 amIs this one any better? It seems to be individual lines in LibreCAD.
yes this is what I wanna have, thank you. This dxf I can open in KiCad too. How did you export it to have individual lines?
Hi Forthman,
yes this works too, thank you!
- wandererfan
There are 2 Dxf exporters - one in the Draft module ("Legacy python exporter") and one in the Import module. Sometimes one works better than the other.
In this case I used the one from the Import module. Just change the preference, then select the Sketch, then File>Export (AutoDesk Dxf).
- UseImportModule.png (123.64 KiB) Viewed 7140 times
The OP is using V0.18 which does not have the 'Use legacy python exporter' option. So the OP would have to switch to V0.19.
- wandererfan
In v0.18, make a TechDraw view of the sketch and use "export page as Dxf" or this in the python console:
>>> import Import
>>> s = App.ActiveDocument.Sketch
>>> Import.writeDXFObject([s], "mbxlv18.dxf")
