You should delete the complete A2plus subfolder in your Mod directory and reinstall the workbench.
Thanks kbwbe, this is the solution
Important information
Just copy the lines and paste them inside code tags. Like this.
Thanks vocx, you are right.
Hi Dan,
<Exception> Geometry.cpp(3829): Geom_TrimmedCurve::parameters out of range
I updated to the new code and the edge constraint works. A couple of 'No control key" programs I'm working also had the same error. They also have this error when I select two planes They use your code but in a different way to return the true/false. The code starts on line 779 and In the Inigui you need to add lines 67 import and line 98.
Hi unit1 I have been trying to create a way to deal with these constraints. If you want to put you file up here I could use a real case problem to see if my idea works. If you want to try the program out I may have it working again in a day or two. but I can try it before then/
Hi, Dan,dan-miel wrote: ↑Mon Jan 20, 2020 5:26 amHi unit1 I have been trying to create a way to deal with these constraints. If you want to put you file up here I could use a real case problem to see if my idea works. If you want to try the program out I may have it working again in a day or two. but I can try it before then/
Dan Miel
