RichAnno scrambled on SVG export
uwestoehr
Post by uwestoehr » Sat Feb 01, 2020 10:00 pm
- open this example file:
TD-test.FCStd
testfile
(138.06 KiB) Downloaded 18 times
- use the menu TechDraw -> Export page as SVG
result:
td-test.svg
SVG result
(138.39 KiB) Downloaded 18 times
As you can see, the RichTextAnno is scrambled in the SVG.
- now use the menu File -> Export PDF
result: everything looks fine:
td-test.pdf
PDF result
(187.61 KiB) Downloaded 9 times
This issue is independent in the SVG namespace issue.
wandererfan
Re: RichAnno scrambled on SVG export
Post by wandererfan » Sun Feb 02, 2020 3:43 pm
The font size for RTA is being written in "user coordinates" (10x in our case), but being interpreted as "absolute coordinates" when read.
Not sure why plain Annotation is not affected by this.
Will have to change the way RTA font size is written to Svg.
wandererfan
Post by wandererfan » Wed Feb 05, 2020 12:41 am
2 of 3 issues (text size & position) fixed by this git commit d68fcb8cc5.
If I've understood what I read, there is no easy fix to the line spacing problem. We'll need
to split the text into individual lines and position each one separately.
uwestoehr
Post by uwestoehr » Wed Feb 05, 2020 11:05 am
I tested and this is what I get now:
actual result
This is what I got before your commit:
former result
Here is the SVG for the box as it should look:
TD-test-correct-box.svg
SVG of only the correctly-looking box
(35.04 KiB) Downloaded 15 times
(I exported the TD page to PDF, then opened the PDF with Inkscape, cleaned it up and saved it as plain SVG.) This SVG shows correct on all 3 browsers I can test (Chrome, Firefox and Edge). This should helps us to find out how to export the RichText box to SVG.
Post by Kunda1 » Wed Feb 05, 2020 3:54 pm
Can we make TechDraw unit test to spot any future regressions of RichTextAnno ?
wandererfan
Post by wandererfan » Thu Feb 06, 2020 1:48 am
Open to suggestions. Not sure how unit test will tell if result "looks right".
wandererfan
Post by wandererfan » Fri Feb 07, 2020 7:51 pm
The problem is that we don't make the Svg in the case of RichTextAnno. We rely on a chain of QTextEdit/QTextDocument/QSvgGenerator and I don't know how many other Qt routines to produce Svg that is equivalent to the original rich text.
I'm leaning towards exporting the RichTextAnno as plain text. This seems to be reliable in terms of delivering a useful result, but of course most of the formatting is lost. That seems better than delivering corrupted text.
wandererfan
Post by wandererfan » Fri Feb 14, 2020 12:57 pm
This commit git commit f00fca547 changes Svg export of RichTextAnno to use plain text. Plain Text appears in approximately the right place on the page and is easily changed in Inkscape.
uwestoehr
Post by uwestoehr » Fri Feb 14, 2020 3:17 pm
But this does destroy the rich text feature and when inserting rich text, I explicitly want this. :?
If there is no border, OK, but now the text size, shape and decorations are all lost. So in fact it is a plain text annotation.
There is also a regression because when you open the example file of my initial commit you get on opening this error:
Reading failed from embedded file: PartShape8.brp (133002 bytes, 49082 bytes compressed)
wandererfan
Post by wandererfan » Fri Feb 14, 2020 6:34 pm
At the moment, the choice is between scrambled rich text or plain text. Rich text to Svg isn't on the table.
this error:
Not sure what this means. We don't read any brep files in TD.
Who is online
