[SOLVED]Numbers display as weird symbols
daboga
Post by daboga »
Hi.
I just downloaded and started to use FreeCAD for the first time.
I have an issue with all number: they do not show up as figures but as meaningless symbols.
The numbers I enter (dimensions, angles...) are well taken into account though.
I attach two screen captures as examples, but this applies to all places where variable numbers are displayed (e.g. also in Preferences).
Version details:
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: French/Belgium (fr_BE)
Bottom right corner of the main window
Dimensions of an object
PrzemoF
Re: Numbers display as weird symbols
Post by PrzemoF »
Welcome to the forum!
Can you try to change language in FreeCAD preferences and check if it makes any difference?
kisolre
Post by kisolre »
PrzemoF
Post by PrzemoF »
Yes, we need hindu-arabic numbers, but itt looks like a dingbat font to me.
kisolre
Post by kisolre »
PrzemoF wrote: Fri Mar 27, 2020 10:52 am but itt looks like a dingbat font to me.
It is not Diingbat font. The numbers in the screenshot are proper arabic numerals. Why are they showed as such I have no idea.
Where did you install FreeCAD? Do you have fancy characters in your user name? Can you check your system settings for displaying numbers. It is important that the decimal separator and the thousands separator are different.
daboga
Post by daboga »
PrzemoF wrote: Fri Mar 27, 2020 10:35 am Welcome to the forum!
Yes, I tried French, German, Italian, Spanish - no effect
daboga
Post by daboga »
chrisb wrote: Fri Mar 27, 2020 1:53 pm Where did you install FreeCAD? Do you have fancy characters in your user name? Can you check your system settings for displaying numbers. It is important that the decimal separator and the thousands separator are different.
I installed FreeCAD from the main site, as far as I know.
Decimal separator is dot (.), thousands separator is white space ( )
I just tried to change the thousands separator to comma (,): no change.
Additional information: in the bottom left corner, the mouse position is correctly displayed (see attachment); it's the only place where it is, as far as I can see.
daboga wrote: Fri Mar 27, 2020 2:17 pm I installed FreeCAD from the main site, as far as I know.
I did not mean from where, where is it on your computer (complete path, probably starting with C:\ )
Please try setting the thousands separator to comma (,) .
daboga
Post by daboga »
chrisb wrote: Fri Mar 27, 2020 2:34 pm
C:\Program Files\FreeCAD 0.18
I already tried the comma (see above): no effect.
There are no special characters in my user name.
