There are 2 NotFound icons?:
https://wiki.freecadweb.org/File:NoIconFound.png
https://wiki.freecadweb.org/File:Std_FreezeViews.svg
2 NotFound icons?
Re: 2 NotFound icons?
hi
no those are 2 different icon if you search in the image you see this image with different name
and if the official image exist (here Std_FreezeViews) then make import a new version of the image for download the official image
this image is displayed if not image or not good translate or not icon exist (pass the mouse over icon)
see Draft_PathArray/de the original english name is translated (image name)
if you correct with Name= Draft PathArray and add Name/de= Draft BahnAnordnung voila
mario
mario
@mario52:
Thanks for you answer. I should have explained better.
The 'freeze' command does not have an icon in the GUI. So why does Std_FreezeViews.svg exist?
I think that SVG and the 9 duplicates should be removed for consistency.
To the GuiCommand template add the "Empty=1" parameter to suppress any icon.
{{GuiCommand
|Name=Std_FreezeViews
|Empty=1
Hey Roy
I've corrected your document.
I found two places that required my intervention.
Check the change stories for details.
Twórca polskiej wersji Wiki dla FreeCAD, współwórca polskiej wersji GUI.
"Cierpliwym być musisz, by wiedzę zgłębiać tajemną, gdyż ciemna strona mocy niszczącą i silną jest".
Not sure which document you are referring to. I have not worked on the https://wiki.freecadweb.org/Draft_PathArray/de page.
My intention was to use the same user name, "Roy_043", on the wiki.
But the wiki has translates "_" to " " (space) so my wiki user name is "Roy 043".
