2 NotFound icons?
Discussions about the wiki documentation of FreeCAD and its translation.
Roy_043
2 NotFound icons?
Post by Roy_043 »
mario52
Re: 2 NotFound icons?
Post by mario52 »
hi
no those are 2 different icon if you search in the image you see this image Image with different name
and if the official image exist (here Std_FreezeViews) then make import a new version of the image for download the official image
this image Image is displayed if not image or not good translate or not icon exist (pass the mouse over icon)
see Draft_PathArray/de the original english name is translated (image name)
if you correct with Name= Draft PathArray and add Name/de= Draft BahnAnordnung voila
mario
Roy_043
Post by Roy_043 »
@mario52:
Thanks for you answer. I should have explained better.
The 'freeze' command does not have an icon in the GUI. So why does Std_FreezeViews.svg exist?
I think that SVG and the 9 duplicates should be removed for consistency.
vocx
Post by vocx »
Roy_043 wrote: Mon Mar 30, 2020 8:16 am The 'freeze' command does not have an icon in the GUI. So why does Std_FreezeViews.svg exist?
To the GuiCommand template add the "Empty=1" parameter to suppress any icon.
{{GuiCommand
|Name=Std_FreezeViews
|Empty=1
kaktus
Post by kaktus »
Hey Roy
:mrgreen:
I've corrected your document.
I found two places that required my intervention.
Check the change stories for details.
Twórca polskiej wersji Wiki dla FreeCAD, współwórca polskiej wersji GUI.
"Cierpliwym być musisz, by wiedzę zgłębiać tajemną, gdyż ciemna strona mocy niszczącą i silną jest".
Roy_043
Post by Roy_043 »
kaktus wrote: Wed Apr 01, 2020 10:16 am I've corrected your document.
Not sure which document you are referring to. I have not worked on the https://wiki.freecadweb.org/Draft_PathArray/de page.
My intention was to use the same user name, "Roy_043", on the wiki.
But the wiki has translates "_" to " " (space) so my wiki user name is "Roy 043".
