IFC Viewer ifcplusplus
Re: IFC Viewer ifcplusplus
Apparently XInitThreads() must be called before running any threaded application. I tried to add this at the beginning of the viewer code, but no luck. I guess it's way more complex than that. Maybe the author of ifcplusplus can help?
Exactly, I did it and it workt for me. I had to add the C++11 standard as well and include X11 and thread. Found it at the internet here http://stackoverflow.com/questions/1151 ... r-using-qtyorik wrote:Apparently XInitThreads() must be called before running any threaded application...
- screen.jpg (136.78 KiB) Viewed 4145 times
Look at that shed! Wow ...think of all the "good stuff" you could put in there ....if you had that shed...and somewhere big enough to fit it.
Since it is possible to import that shed to FreeCAD one could put may be 1.000.000 of the electrical boards inside that shed which could be imported into FreeCAD too (viewtopic.php?f=9&t=5107).jmaustpc wrote:... you could put in there ....if you had that shed...
I gave ifcplusplus running on linux a permanent home on https://github.com/berndhahnebach/IFCPlusPlus
Wow excellent job Bernd! Finally a working linux IFC viewer!
Ah, I had to set EXE_LINKER_FLAGS variable in cmake to "-lX11", you might want to update that...
Just put together the work of others. It's may be getting even better. The maintainer of ifcplusplus has interest in merging the code of the fork from Sylivian Marie (the one my ifcplusplus is based on). It would make ifcplusplus run on osx which is important because most of architects use osx. It means may be we'll get compatible with the main repository. Would be great, would'nt ityorik wrote:Wow excellent job Bernd! Finally a working linux IFC viewer!
Definitely. Maybe the author of ifcplusplus, who claimed it's too much work to maintain a linux version, doesn't realize that it's not so much, now that some helpful people have thrown the bases
One other thing I noticed - and apparently in your screenshot too - is that the icons are missing from the buttons on the left toolbar. Strange, all the resources system seems in place...
Now next urgent task, make the freecad ifc exporter
