[Solved]Freecad looking for Qt_5.15 but Qt_5.12 is installed
davecoventry
Post by davecoventry » Thu Jun 18, 2020 6:27 am
I recently reinstalled my OS (an issue with Virtualbox-don't ask :( ) and, on reinstalling FreeCAD, it fails to run correctly.
/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.15' not found (required by /home/dave/.local/lib/python3.8/site-packages/PyQt5/QtCore.abi3.so)
dave@Tuffy:~$ ls -l /lib/x86_64-linux-gnu/libQt5Core.so.5
lrwxrwxrwx 1 root root 20 Jun 17 22:33 /lib/x86_64-linux-gnu/libQt5Core.so.5 -> libQt5Core.so.5.12.8
I have tried installing Qt from sources, but this has given me Qt6 which also seems incompatible.
OS: Ubuntu 20.04 LTS
Version: 0.18.4.
Python version: 3.8.2
Qt version: 5.12.5
Coin version: 4.0.0
Locale: English/South Africa (en_ZA)
~ Dave
Re: Freecad looking for Qt_5.15 but Qt_5.12 is installed
Post by Kunda1 » Thu Jun 18, 2020 11:06 am
Version: 0.18.4.
Qt version: 5.12.5
Coin version: 4.0.0
How are you installing FC ? BTW, Can you reproduce on 0.19 ?
davecoventry
Post by davecoventry » Thu Jun 18, 2020 1:31 pm
I'm just using the Debian package as installed from the Ubuntu 20.4 repos.
BTW, following the instructions on the Wiki on adding the PPA gives an error:
The repository 'http://ppa.launchpad.net/freecad-maintainers/freecad-stable/ubuntu focal Release' does not have a Release file
To install FreeCAD using the personal package archive (PPA) maintained by the FreeCAD project, please follow these instructions. The repository is called freecad-stable on Launchpad.
Navigate to Ubuntu Software → Software & Updates → Software Sources → Other Software
Click on And, then copy and paste the following line
ppa:freecad-maintainers/freecad-stable
I haven't tried to install the 0.19 candidate, but I would imagine that it also requires Qt5.15 (or possibly later).
~ Dave
openBrain
Post by openBrain » Thu Jun 18, 2020 1:41 pm
Which additional modules did you install ?
AFAIK, FreeCAD doesn't use PyQt at all anymore.
Do you know why PyQt is installed (which software requires it) ?
triplus
Post by triplus » Thu Jun 18, 2020 2:47 pm
davecoventry
Post by davecoventry » Thu Jun 18, 2020 8:56 pm
I'm not sure, but the Draft Workbench, for one, is out of commission.
Screenshot from 2020-06-18 22-51-35.png (302.2 KiB) Viewed 1460 times
@triplus: thanks, I'll have a look at that. I don't have pip installed, though. I'll install it and see if installing PyQt5 though pip works.
~ Dave
sgrogan
Post by sgrogan » Thu Jun 18, 2020 9:04 pm
No. @triplus is worried you have an pip installed package that is messing your system.
If you don't have one, don't make it worse.
"fight the good fight"
triplus
Post by triplus » Thu Jun 18, 2020 10:00 pm
The thing is PyQt5 is already installed and the clash is occurring. Maybe it got installed with some other software, but i have a feeling, that at some point you ran a command, such as:
pip install --user PyQt5
pip3 install --user PyQt5
Hence now try running:
pip uninstall PyQt5
pip3 uninstall PyQt5
And after try running FreeCAD again.
triplus
Post by triplus » Thu Jun 18, 2020 10:04 pm
In addition i did a few quick tests (installed PyQt5 with PIP), and my self compiled FreeCAD, FreeCAD daily from PPA (Ubuntu 16.04) and the daily AppImage work just fine.
Therefore i guess we need to better understand, on why "FreeCAD Ext modules support" has issues with such packages on some systems and not on others.
This likely has borked a few things too. Bottom line, you don't need to install any of this, FreeCAD from repository or PPA will take care of the dependencies. Or download the AppImage, make it executable and run it after:
All dependencies are included.
davecoventry
Post by davecoventry » Fri Jun 19, 2020 12:36 pm
Ok.
Scrubbed my hard drive and installed the operating system again.
Updated and upgraded base system and installed FreeCAD from scratch.
Exactly the same result.
The Appimages work, but are very flakey and prone to segfault. Furthermore, if I import a model altered by the Appimage, there are a number of residual elements.
~ Dave
Who is online
