[Duplicate] Possible bug: Cross-hair misaligned in Sketcher
I am experiencing a bug in the latest windows build of 0.19 (installed today).
The cross hair in sketcher is not actually aligned with the coordinates.
For example, when trying to sketch with auto constraints, I have to aim to the side as can be seen in attached image.
OS: Windows 10 (10.0)
Version: 0.19.22411 (Git)
Hash: d4519d5aec15bc08f029da5ed15410a494b57b2c
Python version: 3.8.5
Qt version: 5.12.6
Coin version: 4.0.0
OCC version: 7.4.0
Locale: English/Denmark (en_DK)
Qt version: 5.12.6
Coin version: 4.0.0
OCC version: 7.4.0
Reason: Duplicate
Reason: Duplicate
Re: Possible bug: Cross-hair misaligned in Sketcher
Hi and welcome to the forum!
There is a certain radius around a point where you can catch the point. You can play with Preferences->Display->Colors->PickRadius. (And yes, we know that the place of this setting is a bit special).
Thanks Chrisb. My concern and the reason that I consider it a bug is that if I actually aim correctly the point will not catch.
Edit:
Edit:
I cannot confirm on MacOS. I have set pick radius to 7.
Can a windows user please confirm?
OS: macOS High Sierra (10.13)
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.4.0
Locale: C/Default (C)
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.4.0
This behaviour is known from 0.18 and was fixed in 0.19. You can try to reset the configuration with the button in the preferences, just in case the versions interfere. Another possibility is to delete your config files or to move them in case you want to restore them.
Deleting the config files did not help. Also deleting the whole config directory did not help.
I fired up the good old 0.18 to check the difference.
There everything is working fine Note that the pointer and cross-hair is a lot smaller in v0.18.
Let's see what other Windows users report.
I have never seen any problem like that. Selection appears dead on.
I am using the "Gesture" mouse model, and the cursor is an arrow, not crosshairs.
OS: Windows 7 SP 1 (6.1)
Python version: 3.6.8
Qt version: 5.12.1
Also tried the Conda version.
Qt version: 5.12.6
Coin version: 4.0.0
OCC version: 7.4.0
Same result; no problem.
Gene
Qt version: 5.12.1
Qt version: 5.12.6
Coin version: 4.0.0
OCC version: 7.4.0
Gene
Hmm, maybe it is a Windows 10 thing. Perhaps a related issue.
Is it intentional that the font size for some of the text labels are so huge.
E.g., the DOCUMENTS, HELP, ... seem to have much larger font size than the rest of the gui.
Still works just fine.
Qt version: 5.12.1
Qt version: 5.12.6
Coin version: 4.0.0
OCC version: 7.4.0
Gene
