I got no reply so i re-post the question, does Hole feature work in your system?
in my Freecad 0.19.22522 (on win7 x64) hole feature doesn't work, i digit parameters but when i close the window they are not applied on the model.
is anyone suffering from it?
[Bug] Hole feature doesn't work
Re: [Bug] Hole feature doesn't work
Created successfully a hole here, changed diameter from 6 to 8mm and changed the depth to 5mm.
OS: macOS 10.15
Version: 0.19.22611 (Git)
Hash: 7eeec7a5990cc786723225ca8de16ca3186545b3
Python version: 3.8.5
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.4.0
Locale: C/Default (C)
OS: macOS 10.15
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.4.0
with 0.19.22522 win-conda doesn't work now I dowload the 0.19.22611_Win-LPv12.1.6_vc14.x-x86-64 and i try
chrisb wrote: ↑Wed Oct 07, 2020 11:37 am Created successfully a hole here, changed diameter from 6 to 8mm and changed the depth to 5mm.
OS: macOS 10.15
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.4.0
Also in 0.19.22611 hole feature doesn't work but for simple one.
Threaded hole, couterbore and countersink don't work
OS: Windows 7 SP 1 (6.1)
Python version: 3.6.8
Qt version: 5.12.1
Locale: Italian/Italy (it_IT)
Qt version: 5.12.1
OS: macOS 10.15
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.4.0
i've installed also 0.18.4 version... could it be the problem?
OS: macOS 10.15
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.4.0
Have you seen this post: https://forum.freecadweb.org/viewtopic. ... 33#p434461?
Seems to be the same as:
https://forum.freecadweb.org/viewtopic.php?f=19&t=50695
so git commit fe3f1b51b7 introduced the problem.
I see no attempt to fix this yet.
