Assistance Please - CAD for a 3D Block??
Re: Assistance Please - CAD for a 3D Block??
Thanks for the comprehensive graphics. Have to have a look tomorrow.
Just had a pretty unproductive time all day looking at other free 3D CAD not online software.
It has been a nightmare. I reckon if I can't draw a simple 3D box with a couple of holes from installing and reading an intro in 15 mins, then it ain't intuitive. eMachineShopCAD was really good and so very simple to use, but obvious that USA company wanted one to use their machine shop and so not all functionality worked, and stl export crashed!!
Most others are rubbish. Wings3D has the Z scale along the base and Y into the air. MS 3D Builder seems to keep all dimensions linked and not clear/simple how to unlink. 3D Crafter didn't want to run and nowhere to set the scale.
So, looks like persevering with FreeCAD. I could be here sometime!!
Intro to block with hole:
- Start new document
- Select part Design workbench
- Click new sketch icon
- Select XY_plane, ok, sketcher opens up.
- Click on rectangle tool icon
- Click opposite corners of rectangle (constrain if desired)
- Click circle tool icon
- Click at center of hole (somewhere inside the previously drawn rectangle)
- Move mouse click (again somewhere inside the previously drawn rectangle)
- (constrain center point and radius if desired)
- Click Close button in Tasks dialog
- Click Pad icon
- Enter a thickness
- Click Ok button
A comment in the Economist recently was that software is becoming less intuitive. Which means more service fees for training!!
Why can't it be as simple to start as eMachineShop CAD.
Draw rectangle
In dimensions set X, Y and Z.
View 3D shape.
Add circle, set depth, select air for hole.
Job done.
Will try that tomorrow.
[/quote]
for more details see the pdf files in the tutorial linked in my signature below...
Mostly because making holes in boxes isn't what everyone wants to do and only what they want to do. Once you get your head around some basics it'll get easier but it's still lots of work as you build more and more complex objects.CRMS wrote: ↑Tue Nov 17, 2020 10:16 pmA comment in the Economist recently was that software is becoming less intuitive. Which means more service fees for training!!
Draw rectangle
View 3D shape.
Job done.
I can't sell this guy enough for his technique for video tutorials. Joko Engineering on youtube. Google - joko engineering freecad
And remember, there are lots and lots of ways to approach these design tasks and sometimes what's in our head isn't the most effective way.
Doug
FreeCAD for Linux
FreeCAD for Linux
OK followed that and fine. Smart block with 1 hole. Now for part 2......
A same size hole at the other end of the block and front/rear rather than top/bottom.
So followed previous instructions. Turned block through 90 to front face.
Sketcher and selecting the different plane, draw circle. Constrain. So sketch001 on front face. So far OK.
Discovered I needed pocket this time rather than pad???
But then filleted edges parallel to holes. Last straight edge came up with "Base feature's shape is not a solid"?? And other end has lines around it??
- 20201119Block.FCStd
- (25.6 KiB) Downloaded 54 times
Hide sketch so you can actually select the edge you want.
A sketch is not a solid obviously!
