DimensionXXX has invalid 2D References
stefano1
Post by stefano1 »
Hi!
v. 0.19: my project uses few spreadsheets and sketches/bodies (furniture panels). everything seems consistent but the report view prints a long list of "DimensionXXX has invalid 2D References". Google can't help. Does anybody know what it means?
Thanks!
andergrin
Re: DimensionXXX has invalid 2D References
Post by andergrin »
You have some over constraint elements in sketch, check out Solver messages
If andergrin's suggestion doesn't help, upload the file.
stefano1
Post by stefano1 »
ok, I will triple-check all the sketches then.
in the meantime..which is the exact dimension in which sketch, that matches "dimensionXXX"?
this is an output:
Dimension096 has invalid 2D References
Dimension097 has invalid 2D References
Dimension022 has invalid 2D References
Dimension026 has invalid 2D References
Dimension029 has invalid 2D References
===== Start Solving System ======
TARGET POS-ACCURACY :1e-05
REACHED POS-ACCURACY :0.0
TARGET SPIN-ACCURACY :1e-05
REACHED SPIN-ACCURACY :0.0
SA SPIN-ACCURACY :0.0
===== System solved using partial + recursive unfixing =====
kisolre
Post by kisolre »
Please provide a file and your FreeCAD version info as per IMPORTANT link above.
I think it is more than just overconstraints. We have seen something similar with references via expressions, where the object got lost. I guess you still use 0.18 (you didn't add your FreeCAD info :roll: ), so I recommend to switch to 0.19. It has improved error and solver messages.
jmaustpc
Post by jmaustpc »
Have you used Draft WB dimensions in your file? Have you got a spreadsheet cell with an alias that contains a space, if so they will fail in an Expression.
stefano1
Post by stefano1 »
no draft WB, and the spreadsheets look ok - double-checked.
I noticed that 2 of my bodies miss their origin, and that is a red-alert in the report view. unfortunately I have no clue, how to reactivate it. any help?
uploading here my file would require a bit of cleanup so I guess I'm better fix all the issues like this "origin" stuff, before.
stefano1
Post by stefano1 »
Well, after a backup, I removed the bodies without origin from the project, plus some outdated techdraws and everything is OK now.
About the missed origins: is there a way to manage it, without redraw everything?
Thanks!
jmaustpc
Post by jmaustpc »
stefano1 wrote: Mon Nov 23, 2020 9:10 am Well, after a backup, I removed the bodies without origin from the project, plus some outdated techdraws and everything is OK now.
Thanks!
Bodies can not have no axis system/origin, if they do then something is corrupted. I know this can happen if you drag and drop something in some circumstances in the treeview.
I think you will find that if you just create a new Body first, then right click on the components of the older corrupt body and select "move to another body", I think that will result in a new non-corrupt body. You may have to check that the attachments of the objects in the new body are set correctly.
