[Solved] Question about FEM examples - mutlimaterial bending beam 5 faces
johnwang
Post by johnwang » Fri Nov 20, 2020 10:13 am
Tried it.
The model is Fusion face1+face2+face3+face4+face5. The value of the FemMaterial1's References is 'Face3[Face1]'. How do I read it? Does it mean:
1. Face3's materrial is FemMaterial1
2. Face1's materrial is FemMaterial1
3. Both are FemMaterial1
4. The face between Face3 & Face1 (which is Fcae2) is FemMaterial1
Any of these true?
Regards,
John
johnwang
Re: Question about FEM examples - mutlimaterial bending beam 5 faces
Post by johnwang » Sat Nov 21, 2020 10:33 am
From FreeCAD\Mod\Fem\femexamples\material_multiple_bendingbeam_fivefaces.py:
Looks like that "Face1" is a bit confusing.
Post by bernd » Mon Nov 23, 2020 10:50 am
better to post a link to the code. but use the commit link to keep it even after a change ... https://github.com/FreeCAD/FreeCAD/blob ... es.py#L136
    material_object1.References = [(doc.Face3, "Face1")]
I will have a look.
The time beeing. If you double cklick in the gui in the FEM Material and select a face in the task panel the face should be hightlighted if the body is visible.
Post by bernd » Mon Nov 23, 2020 10:54 am
yep select the face in tree view material task panel and the face gets hightligthed in 3D-Scene. If not you need to switch visibilities of some objects.
Post by bernd » Mon Nov 23, 2020 11:40 am
seams all good to me ...
- document object "FemMaterial1": element "Face1" of the document object "Face3"
- document object "FemMaterial2": element "Face1" of the document object "Face2 and element "Face1" of document object "Face4"
- document object "FemMaterial3": since references are empty take all the rest
johnwang
Post by johnwang » Tue Nov 24, 2020 3:48 am
All good. Just at the beginning, hard to understand 'face1 of face1'.
It's pretty smart if no reference specified, it will pick the rest objects. I was thinking It applies to all, but wondering why it is at the end.
If I want to retrieve the material values with script, it seems I have to leave the one with no reference at the end.
Who is online
Users browsing this forum: No registered users and 6 guests
