Tried it.
The model is Fusion face1+face2+face3+face4+face5. The value of the FemMaterial1's References is 'Face3[Face1]'. How do I read it? Does it mean:
1. Face3's materrial is FemMaterial1
2. Face1's materrial is FemMaterial1
3. Both are FemMaterial1
4. The face between Face3 & Face1 (which is Fcae2) is FemMaterial1
Any of these true?
Regards,
John
[Solved] Question about FEM examples - mutlimaterial bending beam 5 faces
Re: Question about FEM examples - mutlimaterial bending beam 5 faces
From FreeCAD\Mod\Fem\femexamples\material_multiple_bendingbeam_fivefaces.py:
Looks like that "Face1" is a bit confusing.
better to post a link to the code. but use the commit link to keep it even after a change ... https://github.com/FreeCAD/FreeCAD/blob ... es.py#L136
material_object1.References = [(doc.Face3, "Face1")]
The time beeing. If you double cklick in the gui in the FEM Material and select a face in the task panel the face should be hightlighted if the body is visible.
yep select the face in tree view material task panel and the face gets hightligthed in 3D-Scene. If not you need to switch visibilities of some objects.
seams all good to me ...
- document object "FemMaterial1": element "Face1" of the document object "Face3"
- document object "FemMaterial2": element "Face1" of the document object "Face2 and element "Face1" of document object "Face4"
- document object "FemMaterial3": since references are empty take all the rest
All good. Just at the beginning, hard to understand 'face1 of face1'.
It's pretty smart if no reference specified, it will pick the rest objects. I was thinking It applies to all, but wondering why it is at the end.
If I want to retrieve the material values with script, it seems I have to leave the one with no reference at the end.
Who is online
