I am trying to follow this tutorial http://www.freecadweb.org/wiki/index.ph ... utorial/fr, and got an error when selecting the Solver Object.
Here is the full debug message:
Running the Python command 'Fem_SolverCalculix' failed:
File "/home/odroid/Downloads/FreeCAD-0.16/Mod/Fem/_CommandFemSolverCalculix.py", line 49, in Activated
FreeCADGui.doCommand("FemGui.getActiveAnalysis().Member = FemGui.getActiveAnalysis().Member + [FemSolverCalculix.makeFemSolverCalculix()]")
name 'FemGui' is not defined
Please note that Calculix_ccx is properly installed (2.9.1). I am running Ubuntu 16.04, and Freecad is 0.16.
[EDIT]: I found a workaround to this issue, which seems to be related to the PsicolFils's macro which does not provide an appropriate Mechanical Analysis container for the Calculix Solver. (Remember that I am not using Netgen but GMSH Mesh instead, because I am using Freecad on an Odroid C2 which does not support the appropriate GPU lib required by Netgen).
The workaround is the following:
When your part is ready for FEM, add a standard Mechanical Analysis from the Freecad FEM toolbar, and AFTER create a Mechanical Analysis from Mesh, using the Psicofil's Macro. This way, the FemGui error has gone, and all the forthcoming step went well. (The standard Mechanical Analysis probably provides to the Solver the necessary container, which is not the case from the Psicofil's Macro).
