Cannot change position of object
Very new to cad. This is the first program I've used. I'm beyond grateful for all of the hard work put into this program, and I feel it is a gift to humanity. Thank you ALL!
My problem:
I made a sketch in part design workbench. It is fully constrained. I can freely position the sketch on all 3 axis'. Once I revolve the sketch, I cannot position it. I copied and pasted the revolution into another file, where it was to be added, and also couldn't position it there. I have modeled from sketch to revolution a number of times prior to experiencing this, and never had this issue. I am stumped. I cannot figure out what I've done wrong. I am new enough to this that it's possible I am now doing something different. I have since tried the same process with different, new files. When I sketch then revolve, I cannot change placement.
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
My problem:
Re: Cannot change position of object
That is intended behaviour. To move or rotate a result of Part Design WB you have to move or rotate the basic sketch, the incremental mode might be helpful there. Positioning is different if you use the Part WB. There you can move and rotate the result of an operation as well.
I took a screenshot, but cannot seem to get it here.
You need to save the screenshot as an image file, then you can attach it here.
See https://support.microsoft.com/en-us/hel ... creenshots
Then click on the "Attachments" tab under the text input area. An "Add files" button will appear.
Placement is defined by the placement of the very first sketch in your history of an object. So go to generally the first sketch in your history and change its placement and see what happens.natepat250 wrote:. I can freely position the sketch on all 3 axis'. Once I revolve the sketch, I cannot position it. I copied and pasted the revolution into
Is this still valid ? I mean can;t move an object e.g. a pad without using again its sketch ?chrisb wrote: ↑Mon Feb 20, 2017 2:54 am That is intended behaviour. To move or rotate a result of Part Design WB you have to move or rotate the basic sketch, the incremental mode might be helpful there. Positioning is different if you use the Part WB. There you can move and rotate the result of an operation as well.
Or can;t even move an edge of the pad .
Both attachment and placement can't help ?
i am trying to solve this issue with no avail .
I'm guessing you are attempting to move a feature of the Body.
The body represents a solitary solid which is the accumulation of all features.
In other words, a feature is not a standalone solid, it is part of the solid represented by the Body.
drmacro I am trying to move an object of the body e.g. a cylinder .
Is that possible using attachment or placement ?
You can move it relative to the Body. If you used the Part Design primitive to create the cylinder, then it is part of the construction of the Body and does not stand alone as a separate solid.
Is there any law of the universe (of FC) that you can apply only one placement to a body which is inside a Part-container ?
