onchange and execute functions of python object.
Joel_graff
Re: onchange and execute functions of python object.
Post by Joel_graff » Mon Sep 09, 2019 12:56 pm
Unfortunately, I'm out of my depth when it comes to GDML. I really have never used it.
That said, it might be helpful to post links to the code you're dealing with (I found what I think is the file, but not sure).
Also, have you looked inside the GDML file to verify that your data is being correctly serialized?
The only other thing I can recommend at this point is to create a test case that is stripped down and focused on just this one issue. A bare-minimum example can go a long way to sorting out the issue, especially for others who aren't familiar with your code or thought process.
Nevermind the fact I often find I discover the problem myself when I do that. :)
keithsloan52
Post by keithsloan52 » Mon Sep 09, 2019 3:16 pm
Hi Joel
Don't think it is anything to do with GDML. My import creates a number of objects implemented as FreeCAD Python Objects.
Normally I would expect people to export to GDML, but somebody tested saving as a FreeCAD file FCStd.
When I/they do a reload of the file I get the messages and nothing displayed.
Its something to do with my implementation of Python Objects.
The code is all at https://github.com/KeithSloan/FreeCAD_Python_GDML
the relevant object for the screen shot and messages is GDMLXtru
Test file loaded is xtru3.gdml in SampleFiles
The Objects are in Mod/GDMLObjects.py
Think it is all to do with the Restore of the Python Objects. A number are nested so the file looks like
This is the state after gdml has been imported and about to be saved
as a FC file using Save as
The saved FC file
testA.FCStd
(14.12 KiB) Downloaded 7 times
Keith
Joel_graff
Post by Joel_graff » Mon Sep 09, 2019 3:59 pm
ok, so I got it working on my work machine, only I can't download FCStd's, since they're blocked on the network (zip files...)
I'll try to get it working at some point this week, but I can't really promise anything, atm I'm afraid.
It might be in your best interests to try to write a self-contained macro / example. That way it doesn't have any code in it which isn't directly related to this problem and doesn't require installing your wb.
keithsloan52
Post by keithsloan52 » Fri Mar 27, 2020 7:41 am
Joel_graff wrote:
Thu Sep 05, 2019 3:49 pm
keithsloan52 wrote:
Thu Sep 05, 2019 3:36 pm
Also printing out fp.State gives ['Touched', 'Recompute'] on each on onChange without Restore
So if reassigning the shape is what's causing it, the quick and dirty solution is to set a flag in your fp (e.g. self.no_recompute) and set it to true when reassigning shape.
Then, in your execute function:
def execute(self, obj):
    if self.no_recompute:
        self.no_recompute = False
        return
Are you getting any 'nested recompute' errors in the Report View?
I'm mostly guessing here, without looking at the actual code.
@Joel_graff I am revisiting this
How do I set no_recompute in class __init__?
Or in my case UpdateSet
I have
class GDMLBox :
   def __init__(self, obj, x, y, z, lunit, material, flag = False):
      self.UpdateSet = flag
      obj.Proxy = self
def onChanged(self, fp, prop):
       '''Do something when a property has changed'''
       print(fp.Label+" State : "+str(fp.State)+" prop : "+prop)
       print(self.UpdateSet)
But when restoring a file I get
  File "/home/keith/.FreeCAD/Mod/GDML/freecad/gdml/GDMLObjects.py", line 191, in onChanged
<class 'AttributeError'>: 'GDMLBox' object has no attribute 'UpdateSet'
onekk
Post by onekk » Fri Mar 27, 2020 8:09 am
Your code is wrong.
When you instatiate a class, only the instatiate objects have the porpety assigned.
class GDMLBox :
      obj.Proxy = self
class GDMLBox :
   UpdateSet = False
   some_other_porp = 0.0
      obj.Proxy = self
so every object of class GDML_Box will have the attribute UpdateSet, even if it set to the default false,
The method that load and create the objects have to retrieve the saved attributed and then reassign them.
Regards
Carlo D.
keithsloan52
Post by keithsloan52 » Fri Mar 27, 2020 8:44 am
Your code is wrong.
class GDMLBox :
      obj.Proxy = self
class GDMLBox :
   UpdateSet = False
      obj.Proxy = self
Regards
Carlo D.
But I thought there were TWO types of class variable
  • Class Variable
  • Instance Variable
And what you have suggested is a Class Variable.
Why does an Instance Variable not work?
This link https://wiki.freecadweb.org/FeaturePython_Objects uses Type in a similar way to what I am trying to do.
keithsloan52
Post by keithsloan52 » Fri Mar 27, 2020 9:37 am
Related question in my case.
If you have an Object which is a Part::FeaturePython and one of the properties is a PropertyPartShape
obj.addProperty("Part::PropertyPartShape","Shape","GDMLBox", "Shape of the Box")
When loading a Saved copy of the file, what is the correct way to code to have the Object displayed?
With
Loading a saved file gives
GDMLBox_world0x55d123d0daa0 State : ['Touched', 'Restore'] prop : Proxy
GDMLBox_world0x55d123d0daa0 State : ['Touched', 'Restore'] prop : Visibility
GDMLBox_world0x55d123d0daa0 State : ['Touched', 'Restore'] prop : lunit
GDMLBox_world0x55d123d0daa0 State : ['Touched', 'Restore'] prop : material
GDMLBox_world0x55d123d0daa0 State : ['Touched', 'Restore'] prop : x
GDMLBox_world0x55d123d0daa0 State : ['Touched', 'Restore'] prop : y
GDMLBox_world0x55d123d0daa0 State : ['Touched', 'Restore'] prop : z
GDMLBox_box0x55d123dd2a40 State : ['Touched', 'Restore'] prop : Proxy
GDMLBox_box0x55d123dd2a40 State : ['Touched', 'Restore'] prop : Visibility
GDMLBox_box0x55d123dd2a40 State : ['Touched', 'Restore'] prop : lunit
GDMLBox_box0x55d123dd2a40 State : ['Touched', 'Restore'] prop : material
GDMLBox_box0x55d123dd2a40 State : ['Touched', 'Restore'] prop : x
GDMLBox_box0x55d123dd2a40 State : ['Touched', 'Restore'] prop : y
GDMLBox_box0x55d123dd2a40 State : ['Touched', 'Restore'] prop : z
GDMLBox_world0x55d123d0daa0 State : ['Touched'] prop : Visibility
GDMLBox_box0x55d123dd2a40 State : ['Touched'] prop : Visibility
GDMLBox_world0x55d123d0daa0 State : ['Touched'] prop : Shape
File was not written with this version of the topology
GDMLBox_world0x55d123d0daa0 State : ['Touched'] prop : Shape1
GDMLBox_box0x55d123dd2a40 State : ['Touched'] prop : Shape
GDMLBox_box0x55d123dd2a40 State : ['Touched'] prop : Shape1
GDMLBox_world0x55d123d0daa0 State : ['Touched'] prop : ExpressionEngine
GDMLBox_box0x55d123dd2a40 State : ['Touched'] prop : ExpressionEngine
GDMLBox_world0x55d123d0daa0 State : ['Up-to-date'] prop : Visibility
GDMLBox_box0x55d123dd2a40 State : ['Up-to-date'] prop : Visibility
keithsloan52
Post by keithsloan52 » Fri Mar 27, 2020 9:40 am
Your code is wrong.
class GDMLBox :
      obj.Proxy = self
class GDMLBox :
   UpdateSet = False
      obj.Proxy = self
Regards
Carlo D.
  • Class Variable
  • Instance Variable
Okay I think the problem is when opening a saved file with FeaturePython_Objects the Instance Variables are not reset
as the class __init__ is I assume not being executed.
So if onChanged see's a Restore I am now setting any Instance Variables
i.e.
       # Changing Shape in createGeometry will redrive onChanged
       if ('Restore' in fp.State) :
          self.UpdateSet = False
onekk
Post by onekk » Fri Mar 27, 2020 10:18 am
It depends on how you create the class.
When you create your object you have to define some actions, one action id the __init__ and this is invoked when creating the object.
But when you load ad object, maybe there will be some onLoad() class, where the appropriate instance variables have to be set when the object is loaded and not created.
Carlo D.
keithsloan52
Post by keithsloan52 » Fri Mar 27, 2020 12:34 pm
According to this wiki page https://wiki.freecadweb.org/Creating_a_ ... x,_Part_II there is
onDocumentRestored(self, obj)
Called after a document is restored or a FeaturePython object is copied / duplicated.
Have added to code
def OnDocumentRestored(self,obj) :
       print('Doc Restored')
Who is online
Users browsing this forum: No registered users and 2 guests
