Translating an object along it's axis?
jtidwell
Post by jtidwell » Fri Feb 14, 2020 11:02 am
How can I translate this screw blank along it's axis? I'd like to move it out of the hole about .5mm without changing it's location. Right clicking on the object and using "Translate" doesn't seem to have a linear option nor does "Edit" > "Placement". Maybe I'm just not seeing it?
Re: Translating an object along it's axis?
Post by chrisb » Fri Feb 14, 2020 11:12 am
It is not really possible to say without the model. Usually you should have attached some sketch normal to the cylindrical axis. Then moving along Z-direction would move it along that axis.
kisolre
Post by kisolre » Fri Feb 14, 2020 11:34 am
Also, please attach your images directly to the post. Drag/drop over the text input area or "Attachments" tab under the "Submit" button.
mario52
Post by mario52 » Fri Feb 14, 2020 11:54 am
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
papyblaise
Post by papyblaise » Fri Feb 14, 2020 12:24 pm
Maybe you know the angle of the screw from one axis X or Y
reoriente the scrw along the axis , then translate it , and reposition it at the original angle .
jtidwell
Post by jtidwell » Fri Feb 14, 2020 1:21 pm
Thanks - I've been trying to figure out the "picture" button at the top row of buttons with no success. Thanks for the help.
jtidwell
Post by jtidwell » Sat Feb 15, 2020 9:59 am
Nah, I just used a solid cylinder for the bolt blank and rotated it around to get it where it is now. Unigraphics used to have a floating WCS that you could position somewhere and then reposition an object based on that coordinate system. Was wondering if there was something similar. I ended up using the Part Manipulator plugin to positioning a cylinder .200" thick on the bolt hole, then using P.M. to reposition the bolt on the cylinder, then deleting the cylinder. I should probably figure out a better way to position bolts.
jtidwell
Thank you. That was my thought as well but was hoping for a quicker method.
jtidwell
Post by jtidwell » Sat Feb 15, 2020 10:04 am
hi
Manipulator_Workbench
mario
Hi I ended up using this. Thanks.
mario52
Post by mario52 » Sat Feb 15, 2020 1:56 pm
Hi
ok, this function is available in Placement but not very documented "Deplacement along point to point"
Placement dialog -- arbitrary vertex as center of rotation
mario
Who is online
Users browsing this forum: Google [Bot], looo, oomgoshcd and 9 guests
