Floors that move in sync
paullee
Re: Floors that move in sync
Post by paullee » Thu Mar 26, 2020 1:44 pm
Probably several ways to do it.
E.g.
Input in the z-position of the Lev01 Sketch:
- Sketch.Placement.Base.z + BuildingPart004.Height
so the level of Lev 01 sketch will move depends on Lev00 Sketch's z-position + Floor's Height below
So change the Lev00 Floor Height, the Lev01 move to suit.
Screenshot from 2020-03-26 21-38-17.png (210.57 KiB) Viewed 176 times
Screenshot from 2020-03-26 21-38-49.png (190.85 KiB) Viewed 176 times
file base Freecad_ r.FCStd
(117.54 KiB) Downloaded 1 time
sww1235
Post by sww1235 » Fri Mar 27, 2020 12:51 am
Renato wrote:
Wed Mar 25, 2020 10:34 am
yorik wrote:
Mon Mar 23, 2020 2:22 pm
You could also use expressions for that. Ex: The Z coord of floor 2 = Z coord of floor 1 + height of floor 1
But where you have to write the coordinates of the plan. In placement it allows you to write only numbers!
What is the "level offset"? I put number but nothing apparently happens to me.
See https://forum.freecadweb.org/viewtopic.php?t=36094 for more explanation of what LevelOffset does. I had the same question you did Renato, and I think it is confusingly named at this point. It seems to adjust the z height of the floor label, but not sure what else it does.
Renato
Post by Renato » Fri Mar 27, 2020 10:11 am
thanks, I have seen, in this the objects of the various planes can move together. :)
But:1) however it remains a strange thing. The floor level (ELEV 1 etc.) remains unchanged. So even if the sketch adapts to the height and the objects as well, the measure set remains on the mask of the Floor dimension (only can be entered with a number). So what can be done?
2) how do you link the original sketch to the objects so that they cannot move separately? (in fact if I numerically change the height of the Floor, the sketch moves the objects but the sketch remains still)
3) on version 0.18 does not appear the formula put in the Formula editor, while it appears on version 0.19?
4) where can I find the instructions of what I can write in the formula editor? (Otherwise, most people are excluded from this possibility)
Then I agree that the way level offset is written doesn't seem adequate
paullee
Post by paullee » Fri Mar 27, 2020 3:16 pm
I am afraid I do not understand you. Maybe you describe one problem by one problem.
The formula editor probably was added in 0.19_pre, so just use 0.19_pre :)
Renato
Post by Renato » Fri Mar 27, 2020 10:08 pm
1) there is no correspondence between the objects and the pianon level (see image)
2) How do you link the sketch and the structure it generated? (see image where the sketch remained at different altitude)
Renato
Post by Renato » Fri Mar 27, 2020 10:09 pm
images
elev and placement.jpg (449.38 KiB) Viewed 98 times
elev and placement 2.JPG (426.22 KiB) Viewed 98 times
paullee
Post by paullee » Sat Mar 28, 2020 2:09 am
I still have difficulty to understand the problem you describe... you mean when you move ArchFloor/BuildingPart the Sketch does not move?
I do not use this feature in fact, but I guess ArchFloor will only move ArchObjects only (those w/ their MoveWithHost set to True).
Maybe you can experiment, or someone else can explain ?
Renato
Post by Renato » Sat Mar 28, 2020 5:02 pm
I mean precisely the Floor of Arch which contains objects (walls and structures).
I "placed" my structures on the Arch floors. So I don't want these structures to be placed at different heights from this floor (as happens if I do as you indicated to make the plans move together).
It would take the opportunity to put a formula in the plane positioning, but it is not possible (only numbers, see image 0).
So the goal is to always have the objects linked to the Floor (the grid of the various floors must be seen at the base of the objects).
Then plans are made based on a sketch or wire. The sketches move freely and therefore all the objects of that plane follow the sketch (you can also identify a main sketch, the red one in my example referred to the typical plane, to which to apply the measures.
The sketches of the other planes, if in case , we can also tie them to that.
In any case we have compositional freedom and we can shape the structure instantly).
The next step, if needed, is the possibility of moving the heights of the floors in sync, without the objects moving from their Floor (but it may also not serve and move each floor one at a time and that can be easily done having constrained the objects on the Floor).
The last step is to make the windows placed on the walls follow them in all their movements (I have seen examples on video) and if you wanted to show me better the way would be interesting.At that point everything is coordinated.
If a file that records all the features (setting quotas, etc.) was developed, draft architectural projects could be made quickly
parametric with originator 11.JPG (139.28 KiB) Viewed 49 times
originator and Arch Floor 0.JPG (331.15 KiB) Viewed 49 times
originator and Arch Floor 3.JPG (354.87 KiB) Viewed 49 times
originator and Arch Floor 1.JPG (321.46 KiB) Viewed 49 times
originator and Arch Floor 2.JPG (327.43 KiB) Viewed 49 times
Renato
Post by Renato » Sat Mar 28, 2020 6:26 pm
the Z in the plan also has a formula (I haven't seen it before). So I have the whole plan in coordination (see the Freecad file).
Now we have to make the windows that move with the walls (as I said above) and the sketch with the floor (in the file the sketch remains in its position, while the objects move and I don't like this)
file base Freecad_ r2.FCStd
(114.61 KiB) Not downloaded yet
Renato
Post by Renato » Sat Mar 28, 2020 6:27 pm
Who is online
Users browsing this forum: paullee and 1 guest
