Shortcut for Toggle Edit mode does not work
Roy_043
Post by Roy_043 » Sat Mar 21, 2020 2:31 pm
The shortcut for Edit -> Toggle Edit mode does not work. Shift+E is already used for Std_BoxElementSelection.
Roy_043
Re: Shortcut for Toggle Edit mode does not work
Post by Roy_043 » Mon Mar 30, 2020 8:44 am
Bump.
This is not a big issue, but looks strange as the duplicate shortcuts occur in the same menu.
Syres
Post by Syres » Mon Mar 30, 2020 11:17 am
As a test I changed line 2711 in src\Gui\CommandView.cpp from:
    sAccel        = "Shift+E";
to:
    sAccel        = "Ctrl+Shift+B";
and recompiled and it appears to work as expected but the choice of keys is subjective and whether the StdBoxElementSelection command or the Toggle Edit command should be changed is open for debate as in the 3 years of using FreeCAD I never used that menu selection or the short cut.
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.19.20317 (Git)
Build type: Unknown
Hash: f516c4af0535052eeaf7d436d35eeaab2102e3d7
Python version: 3.6.9
Qt version: 5.9.5
Roy_043
Post by Roy_043 » Mon Mar 30, 2020 2:16 pm
IMO the Edit Mode shortcut can be removed. Most users will probably double click the item in the tree anyway.
Syres
Post by Syres » Tue Mar 31, 2020 2:31 pm
As there's been no other feedback, I've created a PR https://github.com/FreeCAD/FreeCAD/pull/3297 as per your suggestion.
Roy_043
Post by Roy_043 » Tue Mar 31, 2020 6:17 pm
@Syres: Thank you.
yorik
Site Admin
Post by yorik » Mon Apr 06, 2020 11:05 am
Later on we could think of another shortcut there... I'sd like to use TAB, like in Blender, but TAB is very useful too to navigate inside widgets, so not sure...
Who is online
Users browsing this forum: Baidu [Spider], TheMarkster and 11 guests
