[Volunteers welcome] Refactoring the keyboard shortcuts
TheMarkster
Re: [Volunteers welcome] Refactoring the keyboard shortcuts
Post by TheMarkster » Sat Aug 01, 2020 8:52 pm
Offtopic, sort of, but I have to say I loathe vi with a passion. I'm okay with shortcuts, but the most basic of operations -- editing your document -- should be a bit more intuitive. This is coming from somebody who once took great pride in learning the shortcuts for wordperfect for DOS and not needing the keyboard template. Even further offtopic, how grossly mismanaged do you have to be to let your software go from *the* dominant leader in the marketplace to one now nobody who never used a rotary phone ever heard of? Word for DOS was almost as bad as vi back in those days, almost.
On to the topic at hand, if we are to disable workbench shortcuts after leaving the workbench this is something that users should be able to opt out of with a preference. As an example, a shortcut for creating a new spreadsheet or a new sketch could be useful even if you're in another workbench.
I've added some shortcuts to DynamicData, which should not conflict:
D,D,C -- create new dd object
D,D,A -- add new property
D,D,R -- remove property
D,D,S -- open settings
New PR:
https://github.com/FreeCAD/FreeCAD/pull/3768
This will add a new Gui command:
Gui.listCommandsByShortcut(shortcut)
Example:
Gui.listCommandsByShortcut('a,c')
['Std_AxisCross']
Gui.listCommandsByShortcut('')
[all commands without shortcuts as a list of strings]
This can already be done in python, but it's a nice convenience to have, I think.
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
catman
Post by catman » Sat Aug 01, 2020 9:51 pm
I know its picking up off-topic, but maybe I should have mentioned that I really dislike both vi and emacs :lol: .
Its just that I have looked into them enough to understand why some people are fanatic about them.
catman
Post by catman » Sat Aug 01, 2020 9:54 pm
This is D,D for "Dynamic Data", right? Do all your WB shortcuts start with D,D ?
Post by chrisb » Sat Aug 01, 2020 10:01 pm
It would be sufficient, if the current workbench just sets its own shortcuts. If they aren't overwritten they can still be used. So it's a good idea to use multiple key shortcuts, preferably the first one with a modifier, because a simple D key - perhaps for some "Delete" - would make the D,Something keys unavailable.
TheMarkster
Post by TheMarkster » Sat Aug 01, 2020 10:07 pm
Yes, that's the idea. Start them all with d,d.
TheMarkster
Post by TheMarkster » Sat Aug 01, 2020 10:12 pm
Maybe you're right. I'll need to test if there is a conflict in such cases.
That gives me an idea, to provide a wildcard search capability. Something like listCommandsByShortcut('d*')
That would list all commands with shortcuts starting with a 'd'. I'll need to figure out how to do that, probably with a regular expression.
Edit: regular expression support added.
Usage: Gui.listCommandsByShortcut(expr, bUseRegExp)
where expr is a string, which will be interpreted as a regular expression and bUseRegExp is a boolean.
Example:
Gui.listCommandsByShortcut('^d,', True)
[all commands that begin with D,]
Gui.listCommandsByShortcut("Del")
['Std_Delete']
openBrain
Post by openBrain » Sun Aug 02, 2020 9:11 am
As chrisb already highlighted, I'm afraid this way can actually collide pretty easily (in your example, with a 'd' command in any workbench).
To me, if we want to make all workbench commands accessible, a good strategy would be :
  • Limit the 'native' shortcut sequences to 2 strokes (I say stroke rather than key, because for example 'Ctrl+A' is only 1 stroke in a sequence)
  • Define a global stroke that will mean 'Call foreign command' (and of course that will be forbidden for other commands). As example, let's say 'F'.
  • For each workbench, define a 'foreign ID' stroke that would be unique among workbenches. Ideally this ID is stored as a property of the workbench. As example, let's say Part is 'P', Draft is 'D'
So for example, it Part/Cut native shortcut is 'C', when you are in another workbench you have to call it with 'F, P, C'. If Draft/PolarPattern native shortcut is 'P, P', you can call it from another workbench with 'F, D, P, P'.
Obviously the change between native and foreign shall be handle by FC so it's transparent for the user. IMO ideally, the commands of the activated workbench should be accessible with both their native and foreign sequences.
Does that sound sensible guys ?
Post by chrisb » Sun Aug 02, 2020 11:15 am
Yes.
TheMarkster
Post by TheMarkster » Sun Aug 02, 2020 6:26 pm
I have changed the DynamicData default shortcuts. With some additional testing I did find some potential conflicts with Draft workbench. New shortcuts all begin with Ctrl+D:
Ctrl+D,C -- create new object
Ctrl+D,A -- add property to object
Ctrl+D,R -- remove property
Ctrl+D,S -- open settings dialog
By the way, Arch_Frame and Draft_Facebinder both use F:
Arch_Frame = F,R
Draft_Facebinder = F,F
No commands (among workbenches installed on the test machine, which aren't that many) begin with Ctrl+F. I'll go through and install as many of the more commonly used workbenches as I can and test again.
Edit: I installed more workbenches. Now with total of 49 installed and 1547 commands. None begin with Ctrl+F. 2 begin with F (arch frame and draft facebinder mentioned above).
openBrain
Post by openBrain » Sun Aug 02, 2020 7:09 pm
Ctrl+F is interesting. It's not used by workbenches, it's nowhere in the 'customize' editor, it's not really documented ... but it is the shortcut used to do a search in the tree view. ;) So yes, you also have to care about not breaking the 'hardcoded-only' shortcuts. ;)
Who is online
Users browsing this forum: No registered users and 3 guests
