[Solved]Freecad looking for Qt_5.15 but Qt_5.12 is installed
davecoventry
Re: Freecad looking for Qt_5.15 but Qt_5.12 is installed
Post by davecoventry » Fri Jun 19, 2020 1:18 pm
Screenshot from 2020-06-19 14-34-10.png (263.07 KiB) Viewed 728 times
FreeCAD.log
(20.14 KiB) Downloaded 16 times
~ Dave
davecoventry
Post by davecoventry » Fri Jun 19, 2020 1:57 pm
triplus wrote:
Thu Jun 18, 2020 10:04 pm
In addition i did a few quick tests (installed PyQt5 with PIP), and my self compiled FreeCAD, FreeCAD daily from PPA (Ubuntu 16.04) and the daily AppImage work just fine.
Therefore i guess we need to better understand, on why "FreeCAD Ext modules support" has issues with such packages on some systems and not on others.
I have tried installing Qt from sources, but this has given me Qt6 which also seems incompatible.
This likely has borked a few things too. Bottom line, you don't need to install any of this, FreeCAD from repository or PPA will take care of the dependencies. Or download the AppImage, make it executable and run it after:
https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre
All dependencies are included.
Error message before installing PyQt5 with pip:
cannot import name 'QtCore' from 'PyQt5' (unknown location)
dave@Tufness:~$ python -m pip install PyQt5
Collecting PyQt5
  Using cached PyQt5-5.15.0-5.15.0-cp35.cp36.cp37.cp38-abi3-manylinux2014_x86_64.whl (76.6 MB)
Requirement already satisfied: PyQt5-sip<13,>=12.8 in ./.local/lib/python3.8/site-packages (from PyQt5) (12.8.0)
Installing collected packages: PyQt5
Successfully installed PyQt5-5.15.0
Says that PyQt5 is version 5.15.0
Error message changes to:
/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.15' not found (required by /home/dave/.local/lib/python3.8/site-packages/PyQt5/QtCore.abi3.so)
So, on the one hand, it says it can find Qt5, but not the right version, but the version is the correct one.
Uninstall PyQt5 using pip.
dave@Tufness:~$ python -m pip uninstall PyQt5
Found existing installation: PyQt5 5.15.0
Uninstalling PyQt5-5.15.0:
  Would remove:
    /home/dave/.local/bin/pylupdate5
    /home/dave/.local/bin/pyrcc5
    /home/dave/.local/bin/pyuic5
    /home/dave/.local/lib/python3.8/site-packages/PyQt5-5.15.0.dist-info/*
    /home/dave/.local/lib/python3.8/site-packages/PyQt5/*
  Would not remove (might be manually added):
    /home/dave/.local/lib/python3.8/site-packages/PyQt5/sip.cpython-38-x86_64-linux-gnu.so
Proceed (y/n)? y
  Successfully uninstalled PyQt5-5.15.0
Error message reverts to the "unknown loctation".
Freecad
~ Dave
openBrain
Post by openBrain » Fri Jun 19, 2020 2:01 pm
The strange thing is that QtCore should be provided by PySide2, and not PyQt5, in the case of FreeCAD...
triplus
Post by triplus » Fri Jun 19, 2020 2:04 pm
Hi Dave.
Based on all the info you provided i think we are narrowing it down. What is happening is the FreeCAD package you use has the resources compiled with PyQt5. That is where PyQt5 dependency is coming from. This hence likely is a packaging related issue. Is the FreeCAD package installed from the PPA? If yes, then best to notify PPA maintainers.
P.S. Until this gets addressed, installing PyQt5 likely won't help, best to use AppImage.
davecoventry
Post by davecoventry » Fri Jun 19, 2020 3:46 pm
Ok, thanks, that seems likely.
I might try to compile from sources.
~ Dave
sgrogan
Post by sgrogan » Fri Jun 19, 2020 3:57 pm
See this post: https://forum.freecadweb.org/viewtopic. ... 60#p396652
You seem to have the same QT/Pyside2 packaging problem
"fight the good fight"
davecoventry
Post by davecoventry » Sat Jun 20, 2020 3:54 pm
Well, that's fubared.
I uninstalled FreeCAD and downloaded and compiled v0.19-pre.
Fired up FreeCAD-0.19 and have the same error.
I deleted (or, rather, moved) my ~/.FreeCAD hidden directory and the message has changed slightly.
dave@Tufness:/opt/FreeCAD-0.19_pre/freecad-build$ bin/FreeCAD
FreeCAD 0.19, Libs: 0.19RUnknown
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
During initialization the error "/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.15' not found (required by /home/dave/.local/lib/python3.8/site-packages/PyQt5/QtCore.abi3.so)" occurred in /opt/FreeCAD-0.19_pre/freecad-build/Mod/Draft/InitGui.py
Please look into the log file for further information
During initialization the error "/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.15' not found (required by /home/dave/.local/lib/python3.8/site-packages/PyQt5/QtCore.abi3.so)" occurred in /opt/FreeCAD-0.19_pre/freecad-build/Mod/Arch/InitGui.py
During initialization the error "/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.15' not found (required by /home/dave/.local/lib/python3.8/site-packages/PyQt5/QtCore.abi3.so)" occurred in /opt/FreeCAD-0.19_pre/freecad-build/Mod/Tux/InitGui.py
During initialization the error "/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.15' not found (required by /home/dave/.local/lib/python3.8/site-packages/PyQt5/QtCore.abi3.so)" occurred in /opt/FreeCAD-0.19_pre/freecad-build/Mod/AddonManager/InitGui.py
Unknown command 'Std_AddonMgr'
connect failed: No such file or directory
~ Dave
davecoventry
Post by davecoventry » Sat Jun 20, 2020 4:00 pm
Ok, got it.
I've removed the ~/.local/lib/python3.8 directory and it now seems to start ok.
I still seem to have python3.8, though, so it must be install in multiple locations.
I have to say that the different iterations and siblings of python is a complete clusterf*.
I'll put it through a number of tests before I mark thread as solved.
~ Dave
davecoventry
Re: [Solved]Freecad looking for Qt_5.15 but Qt_5.12 is installed
Post by davecoventry » Sun Jun 21, 2020 12:11 pm
Marked as solved.
Thank you, guys. You are a credit to the OS community.
~ Dave
Anool
Post by Anool » Thu Sep 17, 2020 4:20 pm
Well, doing this solved my start up errors too.
I'm on Ubuntu 20.04 fresh install on a formatted disk.
Was having trouble with FC v0.18 installed via Ubuntu software centre, as well as FC v0.18 and FC v0.19 AppImages too.
Who is online
Users browsing this forum: No registered users and 3 guests
