Need plans for wooden barrel (keg)
mickeymantle4
Post by mickeymantle4 »
I AM WORKING on a project for the local senior center building bird houses and we want to make some out of 3/4inch cedar
and got this software to draw plans but I can't make heads or tails out of this , I have never used a cad program before
can some one ether help me make the plan or send me a copy of a plan
the barrel(keg) needs to be 5 inches in diameter and 10 inches tall
thank you
Reason: Changed title from all caps.
sgrogan
Re: Need plans for wooden barrel (keg)
Post by sgrogan »
Hello mickeymantle4 and Welcome to FreeCAD :D
I'm not sure, but are you looking for something like this:
KEG.FCStd
(69.55 KiB) Downloaded 181 times
"fight the good fight"
bejant
Post by bejant »
mickeymantle4 wrote:I AM WORKING on a project for the local senior center building bird houses and we want to make some out of 3/4inch cedar
mickeymantle4 wrote: can some one ether help me make the plan or send me a copy of a plan
I don't know if anyone happens to have such a model or plan. But building a cask shaped birdhouse would be very complicated. For example each stave needs to be beveled and tapered:
So I'm wondering if you're going to do that woodworking ahead of time, or if the seniors will be doing that.
I'm curious too as to why you don't choose a simpler birdhouse:
Image Image
Even something like this would be simpler than a wine cask:
I don't think a bird would care whether or not the birdhouse is keg shaped...
mickeymantle4
we have made the simper ones and want more of a challenge
the pictures on the top are about right but wish it had dimensions and angles
thank you
sgrogan
Post by sgrogan »
mickeymantle4 wrote:the pictures on the top are about right but wish it had dimensions and angles
If your referring to bejant's first picture this is complicated, but not impossible.
If on the other hand you are referring to the straight wall version. Maybe I could help.
mickeymantle4
yes a straight wall barrel would be perfict , It is what I want to do thanks
I need 5" dia and 8" height
bejant
Post by bejant »
mickeymantle4 wrote:I need 5" dia and 8" height
9 staves for each cask, as shown above, all 8" long.
2 ends having 9 equal sides, inscribed in a 3.404" diameter circle, or 3.2" across flats.
And an access hole.
mickeymantle4
thank you that is perfect
subramaniansingh
Post by subramaniansingh »
this is the modal which may help you
wodden barrel
wodden barrel
