Plugin Loader
blackdrum
Re: Plugin Loader
Postby blackdrum » Wed Jul 01, 2015 2:56 am
microelly2 wrote:Oh sorry,
what I wanted:
Open the link in your web browser
select all (ctrl-a)
copy it to the dashboard (ctrl-c)
go to the python console window
paste the dashboard into it (ctrl-v)
wait a minute
restart freecad
Hello
I put the code in the python console, and a get this error
File "<input>", line 12, in st1
File "/usr/bin/../lib/python2.7/os.py", line 157, in makedirs
mkdir(name, mode)
OSError: [Errno 13] Permiso denegado: '/usr/lib/freecad//Mod/plugins/'
Could you tell me what I'm doing wrong?
Regards
E. de Anda.
OS: Linux Mint 17.1 Rebecca
Version: 0.16.5161 (Git)
Build type: None
Hash: 48c25da133271a0caebec74427461f01c234c229
Python version: 2.7.6
Qt version: 4.8.6
microelly2
Re: Plugin Loader
Postby microelly2 » Wed Jul 01, 2015 4:30 am
you need write access to that directory: /usr/lib/freecad/Mod/plugins/
If your are the only user of your pc
sudo chmod a+rw /usr/lib/freecad/Mod/plugins/
if you work in a multiuser environment you still have to run the installations under root-access.
ickby
Re: Plugin Loader
Postby ickby » Thu Jul 09, 2015 8:47 am
I tried it just now on a windows machine, and I get the following error when starting freecad:
Mod pluginloader InitGui.py starting ...
During initialization the error No module named tools occurred in C:\Program Files\FreeCAD 0.15\Mod\plugins\InitGui.py
When trying to use the plugin loader the following happens:
pluginloader started ...
  File "<string>", line 230, in start
TypeError: 'NoneType' object is not callable
microelly2
Re: Plugin Loader
Postby microelly2 » Thu Jul 09, 2015 5:15 pm
I have updated the git:
tools.py and selectiongates.py : https://www.youtube.com/watch?v=_o6gqkX4T9w
blackdrum
Re: Plugin Loader
Postby blackdrum » Fri Jul 10, 2015 3:17 am
microelly2 wrote:Hello,
I did the last steps that you told me, to give the root permition to the dir, and when I run the pluginloader appears this:
error pluginloader
I'm sorry , I'm so bad in this things.
:oops:
microelly2
Re: Plugin Loader
Postby microelly2 » Fri Jul 10, 2015 4:24 am
Nio problem, you have to install the yaml package
 sudo apt-get install python-yaml
blackdrum
Re: Plugin Loader
Postby blackdrum » Sun Jul 12, 2015 12:45 am
microelly2 wrote:Nio problem, you have to install the yaml package
Hello Microelly:
I installed the python-yaml, and when i start FreeCAD, appears the pluginloader, but it happens when is loading the start window of FreeCAD, after this the pluginloader disappears.
Thanks for your help :oops: .
E. de Anda.
OS: Linux Mint 17.2 Rafaela
Version: 0.16.5212 (Git)
Build type: None
Hash: 82a4eb0cecebed15882dc460894b54b591f3301f
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
microelly2
Re: Plugin Loader
Postby microelly2 » Sun Jul 12, 2015 4:07 pm
Pluginloader is a Dock Window
You find it under menu View -> views -> pluginloader
and can activate it
The other parameter you find under menu -> Tools -> Edit parameters
Plugins ==> showdock - this should be set to True
blackdrum
Re: Plugin Loader
Postby blackdrum » Fri Jul 17, 2015 6:29 pm
microelly2 wrote:Pluginloader is a Dock Window
and can activate it
Microelly thank you very much , I can finally use the pluginloader !!!
Regards
E.de Anda.
triplus
Re: Plugin Loader
Postby triplus » Fri Jul 17, 2015 6:59 pm
I noticed this today:
During initialization the error local variable 'fn2' referenced before assignment occurred in .FreeCAD/Mod/freecad-pluginloader-master/InitGui.py
