FEM on Mac OSX
bernd
Re: FEM on Mac OSX
Postby bernd » Mon May 07, 2018 6:45 pm
NO not python, somthing seams wrong with your CalculiX binary ccx. Thus you should try to run just the ccx binary in a shell, or console, I do not know the name in OSX. There should be some output which hopefully will help.
Bernd
Jee-Bee
Re: FEM on Mac OSX
Postby Jee-Bee » Mon May 07, 2018 7:02 pm
Bernd
It's called terminal you're aloud to forget the name ;)
Locost
Re: FEM on Mac OSX
Postby Locost » Tue May 08, 2018 1:18 am
I probably crammed too much info in that last post. I tried running it in terminal (ie ./usr/local/Cellar/calculix-ccx/2.13/bin/ccx_2.13) and got this
dyld: Library not loaded: /usr/local/opt/gcc/lib/gcc/7/libgfortran.4.dylib
Referenced from: /usr/local/Cellar/calculix-ccx/2.13/bin/./ccx_2.13
Reason: image not found
Abort trap: 6
I found an unrelated post by someone with a similar error code with another program. They solved it by uninstalling the program and forcing homebrew to recompile and install (in this case. brew install --build-from-source calculix-ccx). I get an error when I try that.
make: *** [ccx_2.13.a] Error 1
bernd
Re: FEM on Mac OSX
Postby bernd » Tue May 08, 2018 6:50 pm
your ccx binary is somehow broken. Means it has nothing to do with FreeCAD. You need a working CalculiX ccx binary. Since it is OSX I can not help in this regard. The posts in this topic are the best redource I can advice. May be one of the guys from this topic can help ...
Re: FEM on Mac OSX
Postby chrisb » Tue May 08, 2018 8:47 pm
Would it help if I provide the ccx binary (1.5MB 7zipped) or the whole package (8.5 MB 7zipped) for Mac? Compiled under High Sierra.
sgrogan
Re: FEM on Mac OSX
Postby sgrogan » Tue May 08, 2018 9:05 pm
Don't know if it's related but the Travis OSX builds started failing around the date of Locost's first post in this topic.
The self-test error is the always the same, and related to FEM tests? (not the same as Locost's errors, but the same self-test error)
https://travis-ci.org/FreeCAD/FreeCAD/j ... 8953#L8373
Locost
Re: FEM on Mac OSX
Postby Locost » Wed May 09, 2018 2:49 am
chrisb if you can get me the compiled package (say google drive or drop box) hopefully it will help. If that fixes things I'll report the hombrew issue.
Re: FEM on Mac OSX
Postby chrisb » Wed May 09, 2018 6:33 am
Here is a link where you can download the 7zipped package:
https://owncloud.gwdg.de/index.php/s/a8FaSxIpDJzNHuj
it contains the complete subtree /usr/local/Cellar/calculix-ccx/
Locost
Re: FEM on Mac OSX
Postby Locost » Wed May 09, 2018 11:50 am
Thanks for posting that chrisb. I gave the download a shot. I got the same issues and error messages in FreeCAD and terminal as before.
Re: FEM on Mac OSX
Postby chrisb » Wed May 09, 2018 4:13 pm
Sad to hear. If I call ccx I get a simple usage message (first line input, second line output):
Usage: CalculiX.exe -i jobname
