how to get textfiles open into the freecad editor
microelly2
Postby microelly2 » Tue Jun 23, 2015 1:43 pm
To add more comfort I'm looking for a method to open and edit text- and yaml files with the text editor inside freecad.
I can open macros and py-files but other filetypes .txt, .yaml not
csv Files are opened as calculation sheets
how to configure freecad to open text files (and adding a tool for syntax highlighting)
Site Admin
Re: how to get textfiles open into the freecad editor
Postby wmayer » Tue Jun 23, 2015 3:56 pm
FreeCAD.addImportType("Yaml file (*.yaml)","mymodule")
Then mymodule is a Python module that implements the method "open(filename, documentname)". The second parameter can be ignored in your case.
microelly2
Postby microelly2 » Wed Jul 15, 2015 9:19 pm
I have tested this, but it opens a3D window and not a text window
what is wrong with the open method to get a text window?
import os
import FreeCAD
def open(filename):
        docname=os.path.split(filename)[1]
        doc=FreeCAD.newDocument(docname)
       #  fill content
        return doc
Site Admin
Postby wmayer » Wed Jul 15, 2015 10:36 pm
FreeCAD.newDocument
always creates a 3d window.
If you want to have a text editor then create an instance of QTextEdit and add it to the mdi area.
ebrahim raeyat
Postby ebrahim raeyat » Wed Sep 04, 2019 5:00 pm
Thank for your reply. I found it useful, but i want to know if i want to open an existing file format (like *.xlsx), but I want to process my open function, not predefined function. I am writing pyconcrete workbench that reads exported excel file from CSI SAFE software and draw foundation and so on. how can i do that?
thanks for your help.
Site Admin
Postby wmayer » Wed Sep 04, 2019 5:57 pm
With
FreeCAD.addImportType("Excel file (*.xlsx)","mymodule")
you register your module "mymodule" to handle Excel files. When you load an Excel via File > Open then the system searches for the "open" function of the module that has registered the xlsx format and calls it.
bernd
Postby bernd » Wed Sep 04, 2019 8:04 pm
ebrahim raeyat
Postby ebrahim raeyat » Thu Sep 05, 2019 1:30 am
as an example see frd calculix result files in FEM:
https://github.com/FreeCAD/FreeCAD/blob ... nit.py#L37
and
https://github.com/FreeCAD/FreeCAD/blob ... py#L46-L49
Thanks a lot. how can i overwrite default xlsx opening format? now it give me an option to select on of them, but i can't that.
