Ticket #2187 - Unusable Wire from Section
DeepSOIC
Re: Unusable Wire from Section
Postby DeepSOIC » Sat Jun 09, 2018 11:12 pm
Kunda1 wrote:
Sat Jun 09, 2018 1:24 pm
Should we open an upstream ticket about this ?
Maybe...
Or we can just roll our own implementation, like my macro.
DeepSOIC
Postby DeepSOIC » Sat Jun 09, 2018 11:13 pm
BTW, OCC BOPs offer a method to extract section edges, so the implementation can be even simpler than mine.
UR_
Postby UR_ » Sun Jun 10, 2018 8:19 am
OCC docs shows a code snipplet, howto obtain a bspline (up to max 8th degree)
Example : giving two shapes S1,S2 accessing faces, let compute the section edges R on S1,S2, performing approximation on new curves, performing PCurve on part 1 but not on part 2 :
  Standard_Boolean PerformNow = Standard_False;
  BRepBoolAPI_Section S(S1,S2,PerformNow);
  S.ComputePCurveOn1(Standard_True);
  S.Approximation(Standard_True);
  S.Build();
  TopoDS_Shape R = S.Shape();
source: https://www.opencascade.com/doc/occt-6. ... ction.html
while FreeCAD is doing only:
"...\src\Mod\Part\App\FeaturePartSection.cpp"
BRepAlgoAPI_BooleanOperation* Section::makeOperation(const TopoDS_Shape& base, const TopoDS_Shape& tool) const
    // Let's call algorithm computing a section operation:
    return new BRepAlgoAPI_Section(base, tool);
Better should be tested before tickling their tracker :D
Chris_G
Postby Chris_G » Sun Jun 10, 2018 10:25 am
Good catch !
From OCC BRepAlgo_Section the intersection shape is:
analytic where possible ... or a succession of points grouped together in a BSpline curve of degree 1
So the OCC algo is not faulty. It works how it is supposed to.
But adding the Approximation option to Part.Section would indeed be pretty useful.
Chris_G
Postby Chris_G » Sun Jun 10, 2018 4:14 pm
PR 1507 adds the Approximation option to Part.Section.
I hope my PR is good, because C++ is not easy for me. :oops: ... fingers crossed.
Here is the result of the sweep of the original post, with Approximation enabled on the section curve :
