Circle diameter from left to right? Drawing2 plug in WB
Maavhamt
Postby Maavhamt » Mon Aug 03, 2015 1:47 pm
Dear All,
I am trying to dimension the diameter of a circle from bottom left to top right but FreeCAD only lets me do it from bottom right to to top left. If I try to do it from bottom left to top right the dimension line "breaks". On the attached drawing the top circle shows how the dimension line behaves when going from bottom left to top right. Is there a way of changing this? I have looked in Edit Preferences and the Format menu but can't see anything.
Thanks
Maavhamt.
OS: Windows 8
Version: 0.15.4671 (Git)
Branch: releases/FreeCAD-0-15
Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Maavhamt
[/size]
jmaustpc
Re: Circle diameter from left to right?
Postby jmaustpc » Mon Aug 03, 2015 2:08 pm
it looks like you mean dimensions in a Drawing. It looks to me like you are using a third party plug in workbench which Hamish created (i.e. not part of FreeCAD)
Draft Workbench Dimension linked to a circle's edge worked, I just tried it.
triplus
Postby triplus » Mon Aug 03, 2015 11:04 pm
Maavhamt wrote:Dear All,
Thanks
Maavhamt.
OS: Windows 8
Qt version: 4.8.6
I did a quick test and i can rotate the dimension line and can add extension line on top/bottom. Test on more simple drawing first if you get the same behaviour.
Maavhamt
Postby Maavhamt » Wed Aug 05, 2015 11:22 am
No, definitely can't get it to work. I think it's the new version of DimensionDrawing WB with the 0 dps bug fix.
Maavhamt
[/size]
triplus
Postby triplus » Wed Aug 05, 2015 6:22 pm
Maavhamt wrote:No, definitely can't get it to work. I think it's the new version of DimensionDrawing WB with the 0 dps bug fix.
I think i do understand correctly what you are trying to do. And in latest development release + latest Drawing Dimensioning WB i can rotate the dimension line and can add extension line on top/bottom.
There might be a chance i didn't understand correctly what you are trying to do. Or maybe you using production release makes the difference. Could you test latest development release to see if the problem still exists? Or maybe there is an issue with different configuration used as i use defaults and maybe you use some custom setting that produces the mentioned issue.
Maavhamt
Postby Maavhamt » Fri Aug 07, 2015 1:45 pm
Where do I find the development releases? Are they on Github?
I can't see any settings that would cause this behaviour:
Maavhamt
[/size]
mk2
Postby mk2 » Fri Aug 07, 2015 2:08 pm
https://github.com/hamish2014/FreeCAD_d ... its/master
There you find the dev.
Kind Regards
sgrogan
Postby sgrogan » Fri Aug 07, 2015 2:22 pm
@Maavhamt
I can confirm the behavior you describe on:
OS: Windows 7
Version: 0.16.5334 (Git)
Hash: 4f6a50ac271b74381a69f411983ba2758082573a
Qt version: 4.8.6
and a fresh clone of hamish's drawing_dimensioning wb
"fight the good fight"
triplus
Postby triplus » Sat Aug 08, 2015 1:11 am
If this is what you would like to achieve:
I don’t have issues with creating that result on Ubuntu. As @sgrogan confirmed the issue on Windows i am guessing it could be platform specific. I am not sure what could be the cause therefore it probably makes sense to report this issue and hopefully @hamish can test this on Windows to determine the cause.
jmaustpc
Re: Circle diameter from left to right? Drawing2 plug in WB
Postby jmaustpc » Sat Aug 08, 2015 8:06 am
@Maavhamt
This is not part of FreeCAD.
It is an independently developed third party plug in for FreeCAD. I have edited your topic to reflect this.
Using independent plug-ins is part of the FreeCAD design ...and is fine...but mark your topics appropriately so that people understand that you are not talking about FreeCAD. Hamish (the developer) is not likely to find this topic. So you should raise issues with his work on his bug tracker or wherever the third party plug-in is being developed. In this specific case I think he does this on github...but others here could direct you to the correct location.
