Porting to python3
saso
Re: Porting to python3
Postby saso » Sat Jan 12, 2019 12:44 pm
Some of the other files that build the start page are in \data\Mod\Start\StartPage
But I am also not able to load a translation of the start page, for example if I set the language to Slovenian I get
("(unicode error) 'utf-8' codec can't decode byte 0xe8 in position 2: invalid continuation byte", ('<string>', 6, 46, None))
RogerK
Postby RogerK » Sun Jan 13, 2019 9:11 am
I have tested this on my machine. I don't have any Problem to switch translation with the latest build, there is no error printed out. I also tried to switch to Slovenian (at least I think I have choosen this language ;) )
Regarding the Image Issue of the StartPage. I think we should continue this on the original thread https://forum.freecadweb.org/viewtopic. ... 98#p279598 as this looks not like a python 3 issue anymore. I have added there another modification which now also solves the documentation icons.
saso
Postby saso » Sun Jan 13, 2019 9:57 am
You have to restart FreeCAD or close the start page, switch to another WB (for example Sketcher) and back to Start WB. The error is shown in the Report View. I have tested and see this problem with several languages.
RogerK
Postby RogerK » Sun Jan 13, 2019 2:12 pm
I hav tried it again. I changed the language to Slovencina and then restarted FreeCAD and switched between different workbenches and the Start workbench multiple times, but I never get this messages in the report view nor in the python console. I tried the same for German, but no message either.
I used this version of FreeCad for testing (Conda Image):
Version: 0.18.15619 (Git)
Hash: 7d8e5662648b794b5c93e28835a2bf5c1fddffec
Python version: 3.6.6
Qt version: 5.6.2
Locale: German/Switzerland (de_CH)
Syres
Postby Syres » Mon Jan 14, 2019 12:01 pm
Firstly I'm not expecting this to be fixed, as it's a pretty specific hardware combination but maybe worth noting in Known Problems as there maybe a few new users with a similar setup.
I use a Huion 610 tablet only in Blender and Krita to reduce RSI on my right index finger but I have no use for it in FreeCAD and that's not a criticism. No matter whether the tablet is on and responsive or fully disconnected I get a APPCRASH specifically on exit of FreeCAD only with the Py3Qt5 version of the same build, see below.
I ran the debugging function and attach the log file but not sure if it's of any use.
I'm still trying to determine whether certain actions/methods (can't think of a better word) such as Unions, XORs produce a more repetitive crash on exit than Cuts, Slices etc. And yes I'm still a heretic for using the Part WB rather than PD but it works for me.
Problem signature:
  Problem Event Name:	APPCRASH
  Application Name:	FreeCAD.exe
  Application Version:	0.0.0.0
  Application Timestamp:	5c37be20
  Fault Module Name:	wintab32.dll
  Fault Module Version:	1.0.0.1
  Fault Module Timestamp:	58f5d720
  Exception Code:	c0000005
  Exception Offset:	00000000000073af
  OS Version:	6.1.7601.2.1.0.256.48
  Locale ID:	2057
  Additional Information 1:	22a7
  Additional Information 2:	22a79a3edde1d60a457229c0720ffd03
  Additional Information 3:	e7b6
  Additional Information 4:	e7b6c31f343ac2bb8299ec08b615acbe
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
APPCRASH reported using:
OS: Windows 7
Version: 0.18.15611 (Git)
Hash: 64a94ae0f7c60fc981086fe157150a9c0dca29c6
Qt version: 5.6.2
No APPCRASH reported using:
OS: Windows 7
Python version: 2.7.14
OCC version: 7.2.0
FreeCAD.log
(24.26 KiB) Downloaded 19 times
saso
Postby saso » Tue Jan 15, 2019 1:21 pm
About this error I have found this as a possible solution https://stackoverflow.com/questions/124 ... -byte-0x9c
But I don't quite know where in our code I should do this change to test if it works :?
bitacovir
Postby bitacovir » Sun Jan 20, 2019 1:30 pm
I found some errors with this FreeCAD Conda version and some Workbenches when I run the program. These workbenches do not work in this FreeCAD version.
During initialization the error invalid syntax (dimensioning.py, line 53) occurred in C:\Users\Rafael\AppData\Roaming\FreeCAD\Mod\drawing_dimensioning\InitGui.py
Please look into the log file for further information
During initialization the error invalid character in identifier (<string>, line 1) occurred in C:\Users\Rafael\AppData\Roaming\FreeCAD\Mod\fasteners\InitGui.py
Version: 0.18.15656 (Git)
Hash: a60b6957db228c42a00a1e002a415cbb8309d3c8
Qt version: 5.6.2
::bitacovir::
My Blog
Mini Airflow Tunnel Project
yorik
Site Admin
Postby yorik » Mon Jan 21, 2019 12:36 pm
Fasteners works OK for me with python3... Can you try reinstalling it?
drawing_dimensioning indeed is not ported to py3, and probably never will be..
Postby Kunda1 » Mon Jan 21, 2019 12:39 pm
Maybe the addon-manager should give a warning or prompt when downloading WBs that are not py3 compatible or v0.18 compatible ?
Examples of workbenches effected would be: GD&T, Timber, Workfeature etc...
Edit: basically any WB tracked in https://github.com/FreeCAD/FreeCAD-addons/issues/93 that isn't in progress
bitacovir
Postby bitacovir » Mon Jan 21, 2019 7:02 pm
Yes. I reinstalled it and now the message with error of Fasteners has gone.
But now I have this message:
During initialization the error "'BIMWorkbench' already exists." occurred in C:\Users\Rafael\AppData\Roaming\FreeCAD\Mod\BIM.bak\InitGui.py
n
::bitacovir::
My Blog
