The Pip Install went good, but I can't find in freecad-workbench glider? Any tips?
you need to install the dependencies (see link below)I try to "pip Install" openglider for freecad, but I can't find the workbench... Anyone has the same problem?
https://forum.freecadweb.org/viewtopic. ... 90#p346883
@looo is there a section to the workbench README to add these instructions on how to install conda? (it could be in an optional collapsed div)looo wrote: ↑Mon Nov 25, 2019 8:36 amhttps://forum.freecadweb.org/viewtopic. ... 90#p346883
Installing with conda is the simplest way. It should work on mac, linux and windows.
I install all the dependenices, (git clone) i install openglider, but then, whan i open freecad i didn't see the workbench, what can i do?looo wrote: ↑Mon Nov 25, 2019 8:36 amyou need to install the dependencies (see link below)I try to "pip Install" openglider for freecad, but I can't find the workbench... Anyone has the same problem?
conda create openglider openglider freecad.python freecad -c openglider -c freecad/label/dev -c conda-forge
There are also more useful applications:
