[SOLVED] Embedding FreeCAD in ipython
iari
Postby iari » Wed Dec 23, 2015 3:49 pm
I can import FreeCAD module from the external (Anaconda) python console, while I've errors when trying from the ipython console.
In ipython I do:
In [116]: sys.path.append(r'C:\Program Files\FreeCAD 0.15\bin')
In [117]: import FreeCAD
ImportError                               Traceback (most recent call last)
<ipython-input-117-3f6c136746bd> in <module>()
----> 1 import FreeCAD
ImportError: DLL load failed: Impossibile trovare la procedura specificata.
My FreeCAD module path is:
There I find:
FreeCAD.pyd
FreeCADApp.dll
My ipython version:
'2.7.8 |Anaconda 2.1.0 (64-bit)| (default, Jul 2 2014, 15:12:11) [MSC v.1500 64 bit (AMD64)]'
FreeCAD python console version:
'2.7.8 (default, Nov 17 2014, 20:37:05) [MSC v.1800 64 bit (AMD64)]'
FreeCAD version:
OS: Windows 8
Version: 0.15.4671 (Git)
Branch: releases/FreeCAD-0-15
Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Can you help?
Thank you!
igmar
Site Admin
Re: Embedding FreeCAD in ipython
Postby wmayer » Wed Dec 23, 2015 5:06 pm
Here you must write
In [116]: sys.path.append(r'C:\\Program Files\\FreeCAD 0.15\\bin')
because "\b" is an escape sequence and will be interpreted as "\x08".
iari
Postby iari » Wed Dec 23, 2015 5:22 pm
Here you must write
You are right, but the snippet was only one of the trials.. Unfortunately also the right string doesn't resolve.
Site Admin
Postby wmayer » Wed Dec 23, 2015 5:34 pm
The different compiler versions MSC 1800 (=> VS 2013) and MSC 1500 (=> VS 2008) can also be a problem.
So, you should try to find an ipython version built with VS 2013 or you should find a FreeCAD version built with VS 2008.
Site Admin
Postby wmayer » Thu Dec 24, 2015 10:42 am
Yesterday I downloaded the package winpython which also includes ipython
IPython QtConsole 3.2.1
Python 2.7.10 (default, May 23 2015, 09:44:00) [MSC v.1500 64 bit (AMD64)]
Type "copyright", "credits" or "license" for more information.
which I used to test FreeCAD 0.15 with:
Python 2.7.8 (default, Nov 17 2014, 20:37:05) [MSC v.1800 64 bit (AMD64)] on win32
Type 'help', 'copyright', 'credits' or 'license' for more information.
For me it perfectly worked after setting the sys.path to import the FreeCAD module.
iari
Postby iari » Sat Dec 26, 2015 8:31 am
Using ipython from winpython i's a reasonable solution, and it works!
Thanks
igmar
iari
Re: [SOLVED] Embedding FreeCAD in ipython
Postby iari » Mon Dec 28, 2015 3:23 pm
I successfully import FreeCAD modules in ipython (coming with WinPython-64bit-2.7.10.3). But when I try to use makeBSpline I obtain the following error:
In [3]: run testFreeCAD
FreeCAD 0.15, Libs: 0.15R4671 (Git)
AttributeError                            Traceback (most recent call last)
C:\****\testFreeCAD.py in <module>()
     47 # Creazione delle facce
     48 for j in range(0,Nc,1):
---> 49         BSpline = Draft.makeBSpline(points[j*Nr:j*Nr+Nr],closed=False,face=False,support=None)
     50         points2=[points[j*Nr+Nr-1],points[j*Nr+Nr-1]-FreeCAD.Vector(0,0,thick),FreeCAD.Vector(0.0,0.0,0.0)-FreeCAD.Vector(0,0,thick),points[j*Nr]-FreeCAD.Vector(0,0,thick),points[j*Nr]]
     51         Wire1 = Draft.makeWire(points2,closed=False,face=True,support=None)
C:\Program Files\FreeCAD 0.15\Mod\Draft\Draft.pyc in makeBSpline(pointslist, closed, placement, face, support)
    841     true (and wire is closed), the wire will appear filled. Instead of
    842     a pointslist, you can also pass a Part Wire.'''
--> 843     from DraftTools import msg,translate
    844     if not isinstance(pointslist,list):
    845         nlist = []
C:\Program Files\FreeCAD 0.15\Mod\Draft\DraftTools.py in <module>()
     34 import os, FreeCAD, FreeCADGui, WorkingPlane, math, re, Draft, Draft_rc, DraftVecUtils
     35 from FreeCAD import Vector
---> 36 from DraftGui import todo,QtCore,QtGui
     37 from DraftSnap import *
     38 from DraftTrackers import *
C:\Program Files\FreeCAD 0.15\Mod\Draft\DraftGui.py in <module>()
   1791
   1792 if not hasattr(FreeCADGui,"draftToolBar"):
-> 1793     FreeCADGui.draftToolBar = DraftToolBar()
   1794 #----End of Python Features Definitions----#
   1795
C:\Program Files\FreeCAD 0.15\Mod\Draft\DraftGui.py in __init__(self)
    235         self.FORMAT = makeFormatSpec(self.DECIMALS,'Length')
    236         self.AFORMAT = makeFormatSpec(self.DECIMALS,'Angle')
--> 237         self.uiloader = FreeCADGui.UiLoader()
    238
    239         if self.taskmode:
AttributeError: 'module' object has no attribute 'UiLoader'
Indeed, I cannot call FreeCADGui.UiLoader() as UiLoader is not present in FreeCADGui functions..
Any idea?
Thanks
igmar
ipython version:
'2.7.10 (default, May 23 2015, 09:44:00) [MSC v.1500 64 bit (AMD64)]
FreeCAD version:
OS: Windows 8
Qt version: 4.8.6
Site Admin
Postby wmayer » Mon Dec 28, 2015 8:38 pm
You have to also import FreeCADGui and then call its showMainWindow(). This way it gets fully initialized.
import sys
import FreeCAD, FreeCADGui
from PyQt4 import QtGui
app = QtGui.QApplication(sys.argv)
FreeCADGui.showMainWindow()
