add scene graph by iv-string
microelly2
Postby microelly2 » Tue Jan 12, 2016 9:12 am
I want to add an object inside the given scene graph
but instead of using hundreds of coin addChild I want to read in a string in inventor syntax (iv file).
There is a way to get the scene out
obj = FreeCAD.ActiveDocument.ActiveObject
viewprovider = obj.ViewObject
print viewprovider.toString()
But I look for the opposite direction: What is the function to extend the scenegraph by a string?
DeepSOIC
Re: add scene graph by iv-string
Postby DeepSOIC » Tue Jan 12, 2016 10:44 am
I think I managed it once with pivy.SoDB.read(). Was quite some time ago, and it was just some random playaround - I didn't save anything...
microelly2
Postby microelly2 » Tue Jan 12, 2016 12:55 pm
I found this c++
# c++ example
// Read from the string.
SoInput in;
in.setBuffer(dodecahedron, strlen(dodecahedron));
SoNode *result;
SoDB::read(&in, result);
But no idea how to transform it to python
from pivy import coin
inp=coin.SoInput()
FreeCAD.activeDocument().addObject("Part::Box","myBox")
s=FreeCADGui.activeDocument().getObject("myBox").toString()
inp.setBuffer(s,1000)
myNode=coin.SoDB.readAll(inp)
myNode
result=coin.SoSeparator()
myNode=coin.SoDB.read(inp,result)
myNode
result
s=['a','b']
inp.setStringArray(s)
I get these errors
File "/usr/lib/python2.7/dist-packages/pivy/coin.py", line 4692, in setBuffer
return _coin.SoInput_setBuffer(self, *args)
TypeError: in method 'SoInput_setBuffer', argument 2 of type 'void const *'
File "/usr/lib/python2.7/dist-packages/pivy/coin.py", line 4696, in setStringArray
return _coin.SoInput_setStringArray(self, *args)
TypeError: in method 'SoInput_setStringArray', argument 2 of type 'char const *[]'
No idea what char const *[] and void const * means in python :roll:
Site Admin
Postby wmayer » Tue Jan 12, 2016 6:37 pm
There are a couple of functions that are broken in pivy -- or I don't know how to do it. One of them is to set the buffer of the SoInput class.
As alternative you must write the string to a file on disk and then use SoInput.openFile.
looo
Postby looo » Tue Jan 12, 2016 7:45 pm
https://github.com/looooo/pivy/blob/mas ... dString.py this one works for me.
OT:
What about going with PyInventor with the upcoming python3 port? It seems to be more active than pivy and it has nicer syntax, but I don't know how complete it is.
please help with my conda-packaging efforts: https://liberapay.com/looooo/
minimalistic blog: https://looooo.github.io/mini-blog/
microelly2
Postby microelly2 » Tue Jan 12, 2016 8:20 pm
Thank you, nice collection of examples - I was not aware that the inventor mentor examples exist in python too.
But it gives the same error inside freecad,
so I have to go the hard way
I will look for or write my own parser for inventor file syntax.
thanks to +wmayer. For the first I can go through a file.
looo
Postby looo » Tue Jan 12, 2016 9:07 pm
I am sorry I have run the wrong file. This example doesn't work for me either.
microelly2
Postby microelly2 » Tue Jan 12, 2016 9:36 pm
Problem solved - workaround example
import os
from pivy.coin import SoInput,SoDB
dm='''#Inventor V2.0 ascii
Separator {
    RotationXYZ {
       axis Z
       angle 0
    Transform {
       translation 0 0 0.5
    Separator {
       Material {
          diffuseColor 0.05 0.05 0.05
       Transform {
          rotation 1 0 0 1.5708
          scaleFactor 0.2 0.5 0.2
       Cylinder {
tmpname="/tmp/freecad_%s.iv" % os.getpid()
f=open(tmpname,"w")
f.write(dm)
f.close()
mySceneInput = SoInput()
mySceneInput.openFile(tmpname)
myGraph = SoDB.readAll(mySceneInput)
mySceneInput.closeFile()
sg = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
sg.addChild(myGraph)
os.remove(tmpname)
microelly2
Postby microelly2 » Mon Jan 18, 2016 6:37 pm
microelly2 wrote: I will look for or write my own parser for inventor file syntax.
I have now the prototype for a parser for inventor data.
Its not the usual syntax but I can use the syntax of my parser to process Qt and FreeCAD Models too.
I think its more productive to describe different structures the same syntactic way.
After some tests I will improve miki to handle more.
see: http://freecadbuch.de/doku.php?id=blog: ... g_erzeugen
looo
Postby looo » Wed Jan 27, 2016 5:44 pm
"SoInput.setBuffer" should work with this commit.
