create a compsolid out of two boxes
bernd
Post by bernd »
jmaustpc wrote: ... OCE has an item concept of "compsolid". It is like a compound except that the solids in the compound share a single face.
How do I create a compsolid out of two boxes in FreeCAD ?
EDIT: For later reference some links in the regard of CompSolids
OCCT
http://opencascade.blogspot.ch/2009/02/ ... de_27.html
http://www.opencascade.com/content/compsolid-two-solids
https://mail.gna.org/public/pythonocc-u ... 00209.html
GMSH
http://www.geuz.org/pipermail/gmsh/2016/010267.html
FreeCAD:
viewtopic.php?t=5113&start=10#p40380 (similar too: viewtopic.php?f=8&t=13830&start=30#p111073 seams not a valid CompSolid inside FreeCAD 0.16.6214 )
viewtopic.php?f=22&t=13895
viewtopic.php?t=11899
yorik
Founder
Re: create a compsolid out of two boxes
Post by yorik »
Interesting, I had never fully understood the compsolid concept :)
I think it's not implemented in FreeCAD so far..
bernd
Post by bernd »
That would be a pity. At the moment what I need is a BREP of a compsolid which should look like the one in the screen. FreeCAD file attached. There is not much at the internet about compsolids. I found just the link in the first post.
compsolid_wanted.FCStd
(7.36 KiB) Downloaded 83 times
EDIT: for reference the brep of the compsolid_wanted exported from tandersons FreeCAD file
compsolid.brep
(31.02 KiB) Downloaded 263 times
tanderson69
Post by tanderson69 »
if you can get 2 faces in a shell, you can run the shell through part extrude and make a compsolid. Leave the 'create solid' check box UNchecked. Curious to here what you are doing and how it works out. Compsolids are not supported in booleans operations, so they don't seem very useful to me.
compsolid_wanted_ta2.FCStd
(10.41 KiB) Downloaded 79 times
bernd
Post by bernd »
tanderson69 wrote:Curious to here what you are doing and how it works out. Compsolids are not supported in booleans operations, so they don't seem very useful to me.
Wow thanks very much. For FEM analysis 3D tetrahedral meshes are needed. If the part to analyse has different materials none of the tetrahedral mesh elements should cut the contact faces. Means nodes should be on the contact face. Now meshing software GMSH comes in here but this is the case for all open source mesher around. In a compound the contact faces are two faces. One from each solid. The meshing software will make one big glued mesh but the mesh will be not connected at the contact face because of the two faces. If the contact face is planar the meshing software (GMSH) can remove the duplicate faces and glue the mesh together at the contact face but not in case of curved faces. Here comes the compsolid in. If a BREP of a compsolid is passed to GMSH it works (thanks again for providing the compsolid for testing :D ) the mesh is glued and none mesh element cuts the contact face. Attached an FreeCAD FEM file with two materials and a simple tension calculation. Results are included for testing without ccx installed.
FEM_compsolid.fcstd
(63.65 KiB) Downloaded 109 times
Ahh thanks to Jim for is hint in viewtopic.php?t=10846&start=30
Mhh next step. Is it possible to create a compsolid out of two solids or out of a bound of faces like a shere in a cube. Attache another FreeCAD file and a screen.
cube_sphere.fcstd
(3.8 KiB) Downloaded 62 times
tanderson69
ah yes. I forgot. The last guy in here asking about compsolids was doing fem also.
bernd wrote:Mhh next step. Is it possible to create a compsolid out of two solids or out of a bound of faces like a shere in a cube. Attache another FreeCAD file and a screen.
I don't know a way to do it in freecad. It probably is possible in occt drawexe, but it wasn't obvious too me.
tanderson69
Give this a shot. I made it with the following code. If it works, maybe you can duplicate it with pythonOCC. Or make a feature request and link to this thread.
 TopoDS_Solid box = BRepPrimAPI_MakeBox(gp_Pnt(0.0, 0.0, 0.0), gp_Pnt(10.0, 10.0, 10.0)).Solid();
	TopoDS_Solid sphere = BRepPrimAPI_MakeSphere(gp_Pnt(5.0, 5.0, 5.0), 3.0).Solid();
	BRepAlgoAPI_Cut cutter(box, sphere);
	TopoDS_Solid cut = TopoDS::Solid(Utilities::getFirstType(cutter.Shape(), TopAbs_SOLID));
	TopoDS_CompSolid compSolid;
	TopoDS_Builder cBuilder;
	cBuilder.MakeCompSolid(compSolid);
	cBuilder.Add(compSolid, cut);
	cBuilder.Add(compSolid, sphere);
        Utilities::dbusClient()->newDocument("Doc");
        Utilities::dbusClient()->addBrep(QString::fromStdString("Doc"), QString::fromStdString("Box"), Utilities::shapeBrep(box));
        Utilities::dbusClient()->addBrep(QString::fromStdString("Doc"), QString::fromStdString("Sphere"), Utilities::shapeBrep(sphere));
        Utilities::dbusClient()->addBrep(QString::fromStdString("Doc"), QString::fromStdString("Cut"), Utilities::shapeBrep(cut));
        Utilities::dbusClient()->addBrep(QString::fromStdString("Doc"), QString::fromStdString("CompSolid"), Utilities::shapeBrep(compSolid));
compsolid_wanted_ta3.FCStd
(5.91 KiB) Downloaded 59 times
DeepSOIC
Post by DeepSOIC »
I just want to tell, I'm interested in compsolids too. One particular situation, what I'd like to have compsolids, is joinfeatures. I'd love to have an operation, that fuses two solids as shells, and outputs the result as a compsolid. That can be later filtered, and joined into one solid quickly and efficiently. Now, Part JoinConnect is doing five booleans in a row, which makes it veeeeerrryyyy slow.
Founder
Post by wmayer »
In Python:
box=Part.makeBox(10,10,10)
sphere=Part.makeSphere(3,App.Vector(5,5,5))
cut=box.cut(sphere)
compSolid = Part.CompSolid([cut.Solids[0],sphere])
Part.show(compSolid)
teobo
Post by teobo »
even though I see how a compsolid works, (thanks to the preposters and thanks to bernd for pursuing the question)
do not understand the great advantage of a compsolid over a compound, yet. There is a check implied that the "links" of this compound have common faces? That all?
I do not know what is more effort:
Keep it in might or remember a new word for it? (The former I guess)
Well, should not be that difficult to convert a compound to compsolid neither..
