Arch Axis tool on a new document
bitacovir
Postby bitacovir » Tue Feb 09, 2016 1:10 am
Hi. Just I notice when I run FreeCAD and after you open Arch workbench and creating a first empty document, then I click on Arch Axis tool (as first action), the axis is not visible and it has not either axes or values. Only after you draw something in the document you can create an arch axis that is visible. This only happens if you open Arch Workbench previous to create a document:
- open FreeCAD
- open Arch workbench
- create a empty document
- click on Arch axis tool --> the axes element is not visible on the canvas and has not values.
Another thing is some axis values (Angles -Distances) are not editable in the Data Tag of Property window (bottom [...] ). Only if you make double click -> Tasks tag, you can make editions. I think it is a bit confusing.
2016-02-09 12_07_19-FreeCAD.png (54.05 KiB) Viewed 1039 times
OS: Windows 7
Version: 0.16.6398 (Git)
Hash: bb6a66bd824179579ae76dd1bbcbea5eba6f96ed
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
::bitacovir::
My Blog
Mini Airflow Tunnel Project
yorik
Site Admin
Re: Arch Axis tool on a new document
Postby yorik » Tue Feb 09, 2016 4:55 pm
I cannot reproduce the problem... Are you sure the axes are not there, simply out of your current view? (Try zoomig out a bit, or right-click -> fit selection). Maybe what we need is better default settings..
About editing the values in the data tab, indeed. I hadn't even noticed that float lists were editable now :) It works if you take care of using only float values there (1000.0 instead of 1000). The PropertyFloatList editor must probably be fixed/extended so it accepts integer values too -> issue #2444
bitacovir
Postby bitacovir » Wed Feb 10, 2016 10:26 am
yorik wrote:I cannot reproduce the problem... Are you sure the axes are not there, simply out of your current view? (Try zoomig out a bit, or right-click -> fit selection). Maybe what we need is better default settings..
Hi Yorik. I am sure it is not a problem of zoom. I did "ViewFit" but the element remains hidden. If I follow this steps:
- open FreeCAD
The axis element is created hided and it is not visible. I take some screenshots:
2016-02-10 21_17_38-FreeCAD.png (31.04 KiB) Viewed 991 times
Here I included some values to the axis element but it remains hidden.
2016-02-10 21_19_08-FreeCAD.png (10.24 KiB) Viewed 991 times
OS: Windows 7
Qt version: 4.8.6
::bitacovir::
My Blog
rockn
Postby rockn » Wed Feb 10, 2016 10:33 am
Hi !
Strange, I can't reproduce either on:
OS: Ubuntu 14.04.3 LTS
Version: 0.16.6404 (Git)
Build type: Unknown
Branch: path-work
Hash: 7ff4e285999f27b18d396a97e9cb4421504e2d68
Python version: 2.7.6
Qt version: 4.8.6
bitacovir : on the first screenshot we can see the recompute arrows are available, if you recompute after create an Arch system, does it do anything ?
Formations et tutoriels FreeCAD en Français, soutenez moi : https://www.tipeee.com/formations-freecad
jmaustpc
Postby jmaustpc » Wed Feb 10, 2016 11:24 am
for me there is nothing there only because of zoom....if I click on zoom fit all and the Arch Axis appear.
Version: 0.16.6397 (Git)
Build type: Debug
Hash: 6763d3a6e48b6f74d48bca593baa8773897c7220
Qt version: 4.8.6
OCC version: 6.9.1.oce-0.18-dev
rockn
Postby rockn » Wed Feb 10, 2016 11:30 am
As shown by bitavovir's screenshot, the problem is Axis object are hidden (grey in tree view) and that should not happen.
@bitacovir : can you copy/paste the return of Report View and Python console when you perform the operations you describe.
Don't forget to manually recompute if you can.
bernd
Postby bernd » Wed Feb 10, 2016 3:22 pm
bitacovir wrote:I did "ViewFit" but the element remains hidden. If I follow this steps:
- open FreeCAD
Same here on a windows machine:
- open FreeCAD
- click on recompute
- right click view fit
The axis object is grey like bitacovir described.
OS: Windows 7
Qt version: 4.8.6
bernd
Postby bernd » Wed Feb 10, 2016 3:28 pm
Be sure first change to arch wb and than create the new document !
jmaustpc
Postby jmaustpc » Wed Feb 10, 2016 3:29 pm
- open FreeCAD
- open FreeCAD
OS: Windows 7
Qt version: 4.8.6
It must be some how a Windows issue, although its hard to see how, because I tried exactly as you two say above and I get no problems, I just pulled master and tried again, I still get no problems.
I have "Start WB" as my default workbench, in case that makes any difference.
Version: 0.16.6405 (Git)
Build type: Debug
Hash: 45f059d3a91daa9048fc9d7c38c0dc2540f26569
Qt version: 4.8.6
rockn
Postby rockn » Wed Feb 10, 2016 3:32 pm
@bernd, I still can't reproduce.
No output in Report View ?
