modelling a house, some Arch issues
jmaustpc
Postby jmaustpc » Thu Feb 18, 2016 4:17 am
Hi Yorik and all
I just tried to model a small relocatable house with Arch WB, and generally it worked quite well. The last time I tried this was a long time ago.
So I thought I would post here for starters to say thanks for all your work Yorik, the workbench is great. :) And then I will post some issues I discovered.
Merge Walls doesn't seem to work or not work reliably. When I based my walls on path as defined by lines in Sketcher, Join Walls did not do anything. I tried a few random tests with DLine and Dwire with varying correct or incorrect results. I am trying to work out what combination is doing what, I'll write back about that later.
Roof I honestly can not understand. Also If I draw a closed rectangular Dwire (for example 14m x 6m) on z=0 xy plane I get a default strange looking Roof with no errors but if I have the Dwire above z=0 then I get an error message and not roof. Here is the error message for the following file if you make a roof on Dwire002
roof_experiments.fcstd
(20.11 KiB) Downloaded 62 times
le contour contient 4 aretes
PROFIL 0 : Start calculs
Next : ht2 < ht1
a Vector (14168.0996094, -1.9999999999990905, 2400.0)
d Vector (18258.938232445, 4088.838623045002, 2400.0)
e Vector (18258.938232445, 7085.049804700002, 2400.0)
Back : ht0 < ht1
a Vector (-4088.838623045, 7085.0498047, 2400.0)
b Vector (-4088.838623045, 4088.8386230449996, 2400.0)
c Vector (2.0000000000009095, -2.0000000000009095, 2400.0)
('ptsPaneProject', [Vector (14168.0996094, -1.9999999999990905, 2400.0), Vector (18258.938232445, 4088.838623045002, 2400.0), Vector (18258.938232445, 7085.049804700002, 2400.0), Vector (-4088.838623045, 7085.0498047, 2400.0), Vector (-4088.838623045, 4088.8386230449996, 2400.0), Vector (2.0000000000009095, -2.0000000000009095, 2400.0)])
PROFIL 0 : End calculs
PROFIL 1 : Start calculs
Next : ht2 > ht1
a Vector (14168.0996094, -8175.677246089999, 2400.0)
d Vector (18258.938232445, -12266.515869135, 2400.0)
e Vector (18258.938232445, -15262.72705079, 2400.0)
Back : ht1 < ht0
a Vector (18258.938232445, 4088.838623045002, 2400.0)
c Vector (14168.0996094, -1.9999999999990905, 2400.0)
d Vector (14168.0996094, 0.0, 0.0)
('ptsPaneProject', [Vector (14168.0996094, -8175.677246089999, 2400.0), Vector (18258.938232445, -12266.515869135, 2400.0), Vector (18258.938232445, -15262.72705079, 2400.0), Vector (18258.938232445, 4088.838623045002, 2400.0), Vector (14168.0996094, -1.9999999999990905, 2400.0), Vector (14168.0996094, 0.0, 0.0)])
PROFIL 1 : End calculs
  File "/home/user/Downloads/cad/freecad_master/build_master_Release_newgcc_blobfishOCE691_tbb_gl2ps_freeimg/Mod/Arch/ArchRoof.py", line 593, in execute
    f = Part.Face(wire)
<class 'Part.OCCError'>: Failed to create face from wire
I have to run now, I'll be back in a few hours...
Jim
OS: Ubuntu 12.04.5 LTS
Version: 0.16.6431 (Git)
Hash: 69c241ba8972b6b4b89d0a33e2e5eb4c3a7889f7
Python version: 2.7.3
Qt version: 4.8.2
Coin version: 3.1.3
OCC version: 6.9.1.oce-0.18-dev
damian
Re: modelling a house, some Arch issues
Postby damian » Thu Feb 18, 2016 6:40 am
hello jmaustpc:
Recently I drawn a little house. At the beginning, I didn't understand the roof tool. But now it is working very well for me.
I've opened your file. I'm looking the roof001, based in Dwire002. Did you draw the Dwire002 in counter clockwise???
I can't deal with the roof1. But I can draw a new my_Dwire (counter clockwise) and make a new my_roof, inside your file. Later it requires to play with Run and Height in order to obtain a nice roof.
The merge walls seems to be working. I'll see it slower during the day.
Relative to the error message, in another situation with another tool, I've got the same strange message, but it doesn't seem to hurt (for the moment)
jmaustpc
Postby jmaustpc » Thu Feb 18, 2016 4:27 pm
here is a very simple example of two walls from sketches that will not merge
simplewallmergefailureexample3.fcstd
(11.05 KiB) Downloaded 54 times
I get this error message
Running the Python command 'Arch_MergeWalls' failed:
  File "/home/user/Downloads/cad/freecad_master/build_master_Release_newgcc_blobfishOCE691_tbb_gl2ps_freeimg/Mod/Arch/ArchWall.py", line 406, in Activated
    FreeCADGui.doCommand("Arch.joinWalls(FreeCADGui.Selection.getSelection(),delete=True)")
  File "/home/user/Downloads/cad/freecad_master/build_master_Release_newgcc_blobfishOCE691_tbb_gl2ps_freeimg/Mod/Arch/ArchWall.py", line 103, in joinWalls
    FreeCAD.ActiveDocument.removeObject(n)
No document object found with name 'Wall001'
and a very similar file that did work, I just deleted the horizontal second section of the inner wall's path in the sketch
simplewallmergefailureexample3_worked.fcstd
(11.97 KiB) Downloaded 32 times
jmaustpc
Postby jmaustpc » Thu Feb 18, 2016 4:29 pm
damian wrote:Recently I drawn a little house. At the beginning, I didn't understand the roof tool. But now it is working very well for me.
could you post an example FCstd file with a roof that worked?
rockn
Postby rockn » Thu Feb 18, 2016 4:42 pm
Hi Jim,
Yes, I know that Roof tool is not very robust nor very intuitive to use.
But I will need some insane engineer to developp a powerfull Roof builder like I like to use in wood construction software :(
This is my working example that I use to developp this "new" roof tool.
RoofExample.fcstd
(39.92 KiB) Downloaded 59 times
Formations et tutoriels FreeCAD en Français, soutenez moi : https://www.tipeee.com/formations-freecad
jmaustpc
Postby jmaustpc » Thu Feb 18, 2016 5:56 pm
rockn wrote:Hi Jim,
house_2bed_5.fcstd
(374.51 KiB) Downloaded 67 times
thanks rockn
OK but if its helpful.......If I try to make a roof based on your roof's profile I just get the following error
    f = Part.Face(wire)
If I create a similar profile it either just gives me an error or otherwise if makes a roof with the panel going the wrong way down and away from the walls like a veranda and leaves a hole in the middle, the overhang is added to the centre hole rather than outside the wall.
So I was wondering if something else is wrong? Some new bug making it less reliable than normal.
I noticed that your sample does not generate a slab/face on the 90 degree end, I had that problem as well.
For my house, it has a straight Gable roof so I just made two Pads in the end.
Here is the basic file, I made a solid to represent a rough approximation of the ground contours.
house_2bed_5.fcstd
rockn
Postby rockn » Thu Feb 18, 2016 6:37 pm
jmaustpc wrote:If I try to make a roof based on your roof's profile I just get the following error
jmaustpc wrote: If I create a similar profile it either just gives me an error or otherwise if makes a roof with the panel going the wrong way down and away from the walls like a veranda and leaves a hole in the middle, the overhang is added to the centre hole rather than outside the wall.
More or less normal...Once you start editing the roof with right value the roof can be generated. This happen because I made the tool to generate a well shape for a rectangle based wire. But I have an idea to avoid that.
jmaustpc wrote:I noticed that your sample does not generate a slab/face on the 90 degree end, I had that problem as well.
That's intended, to create the gable you can extend the height of the wall slightly higher than the roof and make an Arch substraction between roof and wall.
But I noticed the subShape is not quite high, I will fix that.
damian
Postby damian » Thu Feb 18, 2016 9:28 pm
corregido.fcstd
(282.7 KiB) Downloaded 85 times
damian
Postby damian » Thu Feb 18, 2016 9:58 pm
simplewallmergefailureexample3(join_sketchs_before_make_wall).fcstd
(8.82 KiB) Downloaded 82 times
rockn
Postby rockn » Thu Mar 03, 2016 10:45 am
Hi everyone, hi Jim,
In this pull request : https://github.com/FreeCAD/FreeCAD/pull/108 I made some improvements in roof object.
This is the workflow :
Create a DWire on a horizontal plan.
Select it and make a Roof object. The default value are now fixed (was calculated before).
With a little bit of adjustement you can get this :
Now for the wall below, make it higher than the top of the roof.
Then select Roof and Wall in this order and click the RemoveComponent button (blue minus)
