wrong unit for Arch defaults
bernd
Postby bernd » Thu Mar 10, 2016 6:19 am
EDIT: see thread viewtopic.php?f=23&t=13581 and two workarounds to solve the issue temporary viewtopic.php?f=23&t=13581&start=10#p117644
I seams to have wrong units for Arch defaults, and I do not know how to fix.
- start FreeCAD
- change to arch wb
- check units --> mm
- check Arch defaults --> screen
- new file
- new wall --> default values are
-- l = 0 millimeter
-- w = 20 meter
-- h = 300 meter
- change w to 0.2 m and h to 3.0 m
- make a 10 meter long wall
- select the wall
- add a window
-- same problem all defaults are in meter not in millimeter
screens attached
bernd
Re: wrong unit for Arch defaults
Postby bernd » Thu Mar 10, 2016 7:42 am
Might be the comma is the problem 100 meters are 10000 millimeters. I have changed the FreeCAD languarge to english but I'm on German local and comma is dezimal separator in Germany ?!?
damian
Postby damian » Thu Mar 10, 2016 8:28 am
Hola:
Yes. I have the same problem.
I always have the English language as default, and I have the same problem with defaults measurements.
I've not reported a bug because I haven't got time to study the issue (Also, I'm seeing a little problem with the normal extrusion in structures, but I need to find time to analyze it)
Gracias
Adios.
bernd
Postby bernd » Thu Mar 10, 2016 9:27 pm
It seams a problem of the TaskViewWidget.
If a wall or structure is created by python the values from FreeCAD --> Pref --> Arch --> Defaults are used
import FreeCAD, Draft, Arch
baseline = Draft.makeLine(FreeCAD.Vector(500,0,0),FreeCAD.Vector(5000,0,0))
Arch.makeWall(baseline,None)
Arch.makeStructure()
# take the values FreeCAD, Prefs, Arch, Defaults
yorik
Site Admin
Postby yorik » Fri Mar 11, 2016 2:16 am
Hm the comma/period problem again.. We definitely need to have a better look at that at some point
HoWil
Postby HoWil » Sat Mar 12, 2016 6:55 pm
Can confirm this....
I have km in the window-options menu ;) . See the attached screenshot.
BR
screenshot with km in window-options.
Screenshot km.png (156.23 KiB) Viewed 2462 times
damian
Postby damian » Wed Jun 15, 2016 8:15 am
this is working much better
Also, the attach between window and wall works fine, allowing to turn the wall with the window
Thanks
yorik
Site Admin
Postby yorik » Wed Jun 15, 2016 1:42 pm
I am in the process of replacing the way draft and arch are working with units, and a the proper way instead of the workaround we've been using until now, I believe the comma problem has good chances to disappear now
Fernet
Postby Fernet » Thu Jan 05, 2017 11:05 am
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
Hi there,
the problem still occurs.
Regards
bernd
Postby bernd » Thu Jan 05, 2017 12:05 pm
Fernet wrote:the problem still occurs.Regards
See links in first posts.
