Why does FEM meshing doesn't generate volume elements in some cases
- vejmarie
Re: Why does FEM meshing doesn't generate volume elements in some cases
Hi Bernd,
Enjoy your week-end . Solofo is a friend, he is progressing on the build on linux. He has been able to launch FreeCAD and open the RuggedPOD model. Still face some linking issue on Fem and Mesh, but we might be able to fix all of that pretty soon. When you will restart compilation do not hesitate to pull the git repo (I have pushed 2 fix related to Solofo issues).
vejmarie
vejmarie
@solofo: great so see more people getting involved
udates on netgen5.3.1
I used:
I changed configurescript in the regard of occt directories and libsrc/include/incvis.hpp to get find header file glu.h:
I used:
./configure --with-tclconfig=/usr/lib/tcl8.5 --with-tkconfig=/usr/lib/tk8.5 --with-occ --enable-shared --enable-nglib CXXFLAGS=-DNGLIB_EXPORTS CXXFLAGS="-std=gnu++11"
$ git diff master
diff --git a/netgen-5.3.1/configure b/netgen-5.3.1/configure
index fc3bd2c..40ae3f4 100755
--- a/netgen-5.3.1/configure
+++ b/netgen-5.3.1/configure
@@ -15352,9 +15352,9 @@ fi
if test a$occon = atrue ; then
- OCCFLAGS="-DOCCGEOMETRY -I$occdir/inc -I/usr/local/include/opencascade"
+ OCCFLAGS="-DOCCGEOMETRY -I/usr/local/include/opencascade"
- OCCLIBS="-L$occdir/lib -lTKernel -lTKGeomBase -lTKMath -lTKG2d -lTKG3d -lTKXSBase -lTKOffset -lTKFillet -lTKShHealing -lTKMesh -lTKMeshVS -lTKTopAlgo -lTKGeomAlgo -lTKBool -lTKPrim -lTKBO -lTKIGES -lTKBRep -lTKSTEPBase -lTKSTEP -lTKSTL -lTKSTEPAttr -lTKSTEP209 -lTKXDESTEP -lTKXDEIGES -lTKXCAF -lTKLCAF -lFWOSPlugin"
+ OCCLIBS="-L/usr/local/lib -lTKernel -lTKGeomBase -lTKMath -lTKG2d -lTKG3d -lTKXSBase -lTKOffset -lTKFillet -lTKShHealing -lTKMesh -lTKMeshVS -lTKTopAlgo -lTKGeomAlgo -lTKBool -lTKPrim -lTKBO -lTKIGES -lTKBRep -lTKSTEPBase -lTKSTEP -lTKSTL -lTKSTEPAttr -lTKSTEP209 -lTKXDESTEP -lTKXDEIGES -lTKXCAF -lTKLCAF -lFWOSPlugin"
# -lTKDCAF
diff --git a/netgen-5.3.1/libsrc/include/incvis.hpp b/netgen-5.3.1/libsrc/include/incvis.hpp
index e705a30..b95005d 100644
--- a/netgen-5.3.1/libsrc/include/incvis.hpp
+++ b/netgen-5.3.1/libsrc/include/incvis.hpp
@@ -17,7 +17,7 @@
# include <OpenGL/glu.h>
# else
# include <GL/gl.h>
-# include <glu.h>
+# include <GL/glu.h>
# endif
Making all in nglib
make[2]: Entering directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/nglib'
/bin/bash ../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I. -I.. -I../libsrc/include -DOCCGEOMETRY -I/usr/local/include/opencascade -D_OCC64 -DHAVE_IOSTREAM -DHAVE_LIMITS -DHAVE_LIMITS_H -DHAVE_IOMANIP -std=gnu++11 -fopenmp -MT nglib.lo -MD -MP -MF .deps/nglib.Tpo -c -o nglib.lo nglib.cpp
libtool: compile: g++ -DHAVE_CONFIG_H -I. -I.. -I../libsrc/include -DOCCGEOMETRY -I/usr/local/include/opencascade -D_OCC64 -DHAVE_IOSTREAM -DHAVE_LIMITS -DHAVE_LIMITS_H -DHAVE_IOMANIP -std=gnu++11 -fopenmp -MT nglib.lo -MD -MP -MF .deps/nglib.Tpo -c nglib.cpp -fPIC -DPIC -o .libs/nglib.o
mv -f .deps/nglib.Tpo .deps/nglib.Plo
/bin/bash ../libtool --tag=CXX --mode=link g++ -std=gnu++11 -fopenmp -avoid-version -o libnglib.la -rpath /opt/netgen/lib nglib.lo ../libsrc/interface/libinterface.la ../libsrc/geom2d/libgeom2d.la ../libsrc/csg/libcsg.la ../libsrc/stlgeom/libstl.la ../libsrc/occ/libocc.la ../libsrc/meshing/libmesh.la -L/usr/local/lib -lTKernel -lTKGeomBase -lTKMath -lTKG2d -lTKG3d -lTKXSBase -lTKOffset -lTKFillet -lTKShHealing -lTKMesh -lTKMeshVS -lTKTopAlgo -lTKGeomAlgo -lTKBool -lTKPrim -lTKBO -lTKIGES -lTKBRep -lTKSTEPBase -lTKSTEP -lTKSTL -lTKSTEPAttr -lTKSTEP209 -lTKXDESTEP -lTKXDEIGES -lTKXCAF -lTKLCAF -lFWOSPlugin
libtool: link: g++ -fPIC -DPIC -shared -nostdlib /usr/lib/gcc/x86_64-linux-gnu/4.9/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.9/crtbeginS.o .libs/nglib.o -Wl,-rpath -Wl,/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/interface/.libs -Wl,-rpath -Wl,/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/geom2d/.libs -Wl,-rpath -Wl,/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/csg/.libs -Wl,-rpath -Wl,/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/stlgeom/.libs -Wl,-rpath -Wl,/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/occ/.libs -Wl,-rpath -Wl,/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/libsrc/meshing/.libs -Wl,-rpath -Wl,/opt/netgen/lib ../libsrc/interface/.libs/libinterface.so ../libsrc/geom2d/.libs/libgeom2d.so ../libsrc/csg/.libs/libcsg.so ../libsrc/stlgeom/.libs/libstl.so ../libsrc/occ/.libs/libocc.so ../libsrc/meshing/.libs/libmesh.so -L/usr/local/lib -lTKernel -lTKGeomBase -lTKMath -lTKG2d -lTKG3d -lTKXSBase -lTKOffset -lTKFillet -lTKShHealing -lTKMesh -lTKMeshVS -lTKTopAlgo -lTKGeomAlgo -lTKBool -lTKPrim -lTKBO -lTKIGES -lTKBRep -lTKSTEPBase -lTKSTEP -lTKSTL -lTKSTEPAttr -lTKSTEP209 -lTKXDESTEP -lTKXDEIGES -lTKXCAF -lTKLCAF -lFWOSPlugin -L/usr/lib/gcc/x86_64-linux-gnu/4.9 -L/usr/lib/gcc/x86_64-linux-gnu/4.9/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.9/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.9/../../.. -lstdc++ -lm -lgomp -lpthread -lc -lgcc_s /usr/lib/gcc/x86_64-linux-gnu/4.9/crtendS.o /usr/lib/gcc/x86_64-linux-gnu/4.9/../../../x86_64-linux-gnu/crtn.o -fopenmp -fopenmp -Wl,-soname -Wl,libnglib.so -o .libs/libnglib.so
libtool: link: ( cd ".libs" && rm -f "libnglib.la" && ln -s "../libnglib.la" "libnglib.la" )
g++ -DHAVE_CONFIG_H -I. -I.. -I../libsrc/include -DOCCGEOMETRY -I/usr/local/include/opencascade -D_OCC64 -DHAVE_IOSTREAM -DHAVE_LIMITS -DHAVE_LIMITS_H -DHAVE_IOMANIP -std=gnu++11 -fopenmp -MT ng_vol.o -MD -MP -MF .deps/ng_vol.Tpo -c -o ng_vol.o ng_vol.cpp
mv -f .deps/ng_vol.Tpo .deps/ng_vol.Po
/bin/bash ../libtool --tag=CXX --mode=link g++ -std=gnu++11 -fopenmp -o ng_vol ng_vol.o libnglib.la ../libsrc/interface/libinterface.la ../libsrc/geom2d/libgeom2d.la ../libsrc/csg/libcsg.la ../libsrc/stlgeom/libstl.la ../libsrc/occ/libocc.la ../libsrc/meshing/libmesh.la -L/usr/local/lib -lTKernel -lTKGeomBase -lTKMath -lTKG2d -lTKG3d -lTKXSBase -lTKOffset -lTKFillet -lTKShHealing -lTKMesh -lTKMeshVS -lTKTopAlgo -lTKGeomAlgo -lTKBool -lTKPrim -lTKBO -lTKIGES -lTKBRep -lTKSTEPBase -lTKSTEP -lTKSTL -lTKSTEPAttr -lTKSTEP209 -lTKXDESTEP -lTKXDEIGES -lTKXCAF -lTKLCAF -lFWOSPlugin
libtool: link: g++ -std=gnu++11 -fopenmp -o .libs/ng_vol ng_vol.o ./.libs/libnglib.so ../libsrc/interface/.libs/libinterface.so ../libsrc/geom2d/.libs/libgeom2d.so ../libsrc/csg/.libs/libcsg.so ../libsrc/stlgeom/.libs/libstl.so ../libsrc/occ/.libs/libocc.so ../libsrc/meshing/.libs/libmesh.so -L/usr/local/lib -lTKernel -lTKGeomBase -lTKMath -lTKG2d -lTKG3d -lTKXSBase -lTKOffset -lTKFillet -lTKShHealing -lTKMesh -lTKMeshVS -lTKTopAlgo -lTKGeomAlgo -lTKBool -lTKPrim -lTKBO -lTKIGES -lTKBRep -lTKSTEPBase -lTKSTEP -lTKSTL -lTKSTEPAttr -lTKSTEP209 -lTKXDESTEP -lTKXDEIGES -lTKXCAF -lTKLCAF -lFWOSPlugin -fopenmp -Wl,-rpath -Wl,/opt/netgen/lib
../libsrc/occ/.libs/libocc.so: undefined reference to `IGESCAFControl_Reader::IGESCAFControl_Reader()'
../libsrc/occ/.libs/libocc.so: undefined reference to `IGESCAFControl_Reader::SetColorMode(unsigned int)'
Makefile:460: recipe for target 'ng_vol' failed
make[2]: *** [ng_vol] Error 1
make[2]: Leaving directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1/nglib'
Makefile:354: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/home/hugo/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1'
Makefile:285: recipe for target 'all' failed
make: *** [all] Error 2
EDIT:
commented in configure script:
#ac_default_prefix="/opt/netgen"
it's compiling ...
no still an undefined reference on netgen 5.3.1 ...
hugo@weide:~/Documents/dev/netgen/netgen-vejmarie/netgen-5.3.1$
recompiled your updated FreeCAD occt7.0.0 without netgen. See the really small changes I had to make on cmakesvejmarie wrote:I have pushed 2 fix related to Solofo issues
https://github.com/berndhahnebach/FreeC ... 700569149e
But still on changing to Part or Fem ...
first time:
/home/hugo/Documents/dev/freecad/freecadbhb_vejmarie/build/Mod/Part/Part.so: undefined symbol: _ZNK18IGESControl_Writer5ModelEv
segmentation fault
- vejmarie
I am building a vagrant provisioning script out of debian/jessie64, so it might be helpfull to you guys Stay tune it shall be available during the night
- vejmarie
Good news guys, I have been able to recompile the stuff under linux with everything which works. I will publish a vagrant file tonight as to help you, but the run has been made on a fresh Debian/Jessie64 running under VirtualBox ...
So you shall be able to make it work. I have published a few fix on my git, just re-pull it. Other things, I have installed all the libraries within there STANDARD destination directory (like /usr/local), and copied netgen source tree into /usr/share/netgen as the FindNETGEN.cmake is looking for that directory even if it is strange
Here a quick screenshot !
Wow cool ! I'm really curious! I have spent quite some time on this now ...vejmarie wrote:Good news guys, I have been able to recompile the stuff under linux with everything which works. I will publish a vagrant file tonight as to help you, but the run has been made on a fresh Debian/Jessie64 running under VirtualBox ...
- vejmarie
@bernd, @solofo, here is the vagrant file which works
https://gist.github.com/vejmarie
You need to download the Vagrantfile and FreeCAD.sh which is the provisioning script. It does generate a working FreeCAD with OCCT 7 and new Salome version on Debian/Jessie64 vagrant box.
Enjoy, just let me know if you have any issues !
vejmarie
vejmarie
@vejmarie
It seems compilation with FreeCAD.sh worked thanks!
Used schroot/debootstrap instead of vagrant because the build machine is already a debian (stretch/sid), so this is more lightweight than vagrant/virtualbox, and probably easier for display export.
