Topology optimization
RatonLaveur
Re: Topology optimization
Postby RatonLaveur » Wed Sep 25, 2019 6:01 pm
Dude, this is positively awesome!
(yeah I'm at a loss for words)
shIxx
Postby shIxx » Sat Sep 28, 2019 11:20 am
Thank you for this great work.
I know topology optimization is hard to compare, but I dared try it.
beso vs z88Arion vs Ansys,.. Unfortunately I had to exclude ToOptix because I work with FreeCAD .19 and python 3
I used the same mesh on all three solvers. The mesh was generated by Netgen from the FEM WB. Otherwise I tried to set all parameters s the same as good as possible
System:
CPU: i7 3930k 6c 12t @☺ 3,9GHz
RAM: 12Gb DDR3 @ 800MHz
Windows 10 64bit
In short: beso is very slow but also gives very good results. I even find that it often gives the best results, but everyone has to decide for themselves
Here some screenshots. For a closer look, I attached the pdf file.
Topologie-vergleich.zip
(962.54 KiB) Downloaded 61 times
shIxx
Postby shIxx » Sat Sep 28, 2019 2:16 pm
Here is another comparison.
Von Mises stress [MPa] original and optimized relatively well spread:
RatonLaveur
Postby RatonLaveur » Mon Sep 30, 2019 6:44 am
Thank you for this great comparison. It seems evident that beso is on fighting ground with Ansys.
I wonder if Z88 Arion's comparatively simpler output is a measure of how effective it is or too simplistic a calculation.
However, the calculation times seem to show that beso could benefit from some level of optimization. I wonder if it is using all the resources (threads/cores) of the computer you used.
shIxx
Postby shIxx » Mon Sep 30, 2019 8:20 am
Beso only has the ability to optimize for stiffness, this is why I've used the CO solver in Arion which does very fast iterations based on stiffness. Maybe it would have been better to use TOSS. I thought it would be unfair to compare but maybe not, because beso also adds material. That's what the SKO and TOSS solver do in Arion. The TOSS solver is also relatively slow.
And due to the limitation of Ansys academic (<32k nodes and elements) I had to use a rough mesh. Certainly Arion's result will look different with a finer mesh.
II've noticed that beso often takes away material (especially at the load surface) and in the next few iterationen adds the same material again and so on. If it were possible to exclude areas (surfaces, edges, volumes), then you could save many iteration steps.
I think so, because the output says:
 Using up to 12 cpu(s) for the stress calculation.
 Using up to 12 cpu(s) for the symmetric stiffness/mass contributions.
 Factoring the system of equations using the symmetric spooles solver
 Using up to 12 cpu(s) for spooles.
It looks like Beso doesn't use the CPU optimally. I have too little programming knowledge, but it seems that beso spend too much time for something in the background (read and write data or something else) and less for the actual calculation.
fandaL
Postby fandaL » Mon Sep 30, 2019 11:07 am
CalculiX uses all CPU threads (not whole time it is running). BESO inside does not use more threads.
Second note is that if you would run larger and larger tasks you would notice that CalculiX takes smaller and smaller portion of the optimization time. This is due to data structure which gets rapidly slower if they contain many members.
BESO is in principle simpler method (maybe to simple), you can change its “speed” by the slider in GUI, but results could change.
Another point is about multiple load cases which are not in the comparison, but in real application they are often necessary. In CalculiX you would need to add new steps to inp file for other load cases which would do almost all the work again for each load case in CalculiX, but some solvers can solve them very efficiently.
It is possible to define second material in FreeCAD for top flange and not include it to the optimization domain or define it as the non-design domain.
shIxx
Postby shIxx » Mon Sep 30, 2019 2:46 pm
Thanks, I didn't know that.
That means I need a model with at least two materials but if I try to add a different material to a surface, CalculiX shows me this error "it is not possible to have different reference shape types for material objects at the moment".
Ok I think I have to create a compsolid of several bodies in order to assign different materials.
To change the geometry instead of defining the surfaces with just a few clicks is a bit laborious. :cry:
However, it's great to have the possibility for topology optimization in FreeCAD.
@fandaL Have you ever thought about integrating this into the FEM WB? Please talk with the FEM guys,.. this would be awesome!
It's amazing what is possible with open source software these days!
I will play around with BESO a while. Obviously I have nothing better to do on vacation,... especially on this rainy day :D
EDIT:
somehow I can no longer use my keyboard in FreeCAD after BESO is finished. The arrow keys are working but space, del or contr+c are not. To restart FreeCAD helps.
fandaL
Postby fandaL » Mon Sep 30, 2019 9:19 pm
I’m not sure if it is intended workbenchworkflow but dirty way can be to define another cube, shift it to overlap original geometry a bit and than define a new material on the cube (which has nothing to do with a mesh object).
Later I will look how to make it available through Addon Manager as a macro. As regards topology optimization directly in official FEM wb, IMHO it would be worth only with big changes, maybe turning to different method or implementing ToOptix.
fandaL
Postby fandaL » Thu Oct 03, 2019 8:18 pm
fandaL wrote:
Tue Sep 24, 2019 8:44 pm
When error is made by the GUI, FC0.18 crashes. https://github.com/fandaL/beso/issues/5
A bit annoying is that CalculiX opens everytime in foreground. https://github.com/fandaL/beso/issues/6
It should work with updated code.
It was due to same bug as with 0.18 crashes.
Blaze
Postby Blaze » Thu Oct 17, 2019 11:01 am
Hi All,
Can anyone describe how exactly should I prepare model and mesh if I ahve a regions which i don't want to optimize ? I am trying with boolean operatons but it seems to not work.
