zbigg wrote: ↑Tue Apr 17, 2018 4:24 pm
SHortcut implementation drives me nuts.
Try to assign the keys: ASSIGN greyed out, inactive.
Try to clear the keys: CLEAR does not work
Whats going on?!
OK, I think I get the confusion.
- Capture.PNG (44.4 KiB) Viewed 1283 times
Assign and Clear refer to the "Press new shortcut:" field. Maybe clear should be greyed out if the field is empty.
Also FreeCAD uses "lazy loading" so if you have not loaded, Arch or Draft their shortcuts have not been initialized.
Cycle through the workbench selector for the workbenches that you use frequently, then try to customize. A re-start is required for the changes to take effect , at least for python wb's like arch and draft.
Also many of the "good" shortcuts may already be taken.
