Fem constraint contact
UR_
Re: Fem constraint contact
Postby UR_ » Tue Aug 29, 2017 4:40 pm
JV_3D wrote:
Tue Aug 29, 2017 2:49 am
Why is this different results means?
This means, ccx is in trouble finding a convergent iteration sequence.
Unfortunately ccx builds for windows are less stable than native linux builds (so they say).
I've tested several builds against stability under iterative load, and there are differences!
Don't know which build is bundled with FreeCAD, but i can confirm your results.
If you are running into problems, please try this:
https://github.com/ddfem/ccx_mingw64/bl ... 2_MTNO.exe
most stable because of non optimized code
Much less faults on ccx's test suite!
In single thread mode it will finish.
Unfortunately we have no analytic result for this example, so we couldn't do any verification.
But at least a hint to get this work with bundled ccx.exe:
Change degree of elements from 2 to 1 (most important!!)
For better results refine mesh at least to max size 10,0
netgen params.png (14.55 KiB) Viewed 2214 times
UR_
Postby UR_ » Tue Aug 29, 2017 5:54 pm
2) I am using other example but ... how should I continue?
I think, there are several things gets mixed up.
Get your facts first, then you can distort them as you please. Mark Twain
ccx supports rougly spoken 3 types of contact:
1) surface/surface contact accessible by FreeCAD's GUI
This contact prevents from intrusion, but not from sliding and not from lifting
It's build from spring elements, which generates forces only on negative clearance (intrusion)
2) TIED surface/surface contact
You have to edit .inp file after generation and before starting ccx
See reddish parts
** Contact Constraints
** written by write_constraints_contact function
** FemConstraintContact
*CONTACT PAIR, INTERACTION=INT1,TYPE=SURFACE TO SURFACE
DEP1,IND1
*SURFACE INTERACTION, NAME=INT1
*SURFACE BEHAVIOR,PRESSURE-OVERCLOSURE=TIED
1000000.0
*FRICTION
0.1, 1000000.0
In this case spring elements are generated, which can produce push AND pull forces
3) *TIE, see this post for referencehttps://forum.freecadweb.org/viewtopic. ... IE#p180709
In this case rigid links are used for connecting faces.
Your example won't work, because there is no static equilibrium, if you use FreeCAD's standard type of contact (see #1)
I've tested your file with #2, which worked.
JV_3D
Postby JV_3D » Wed Aug 30, 2017 1:09 am
bernd wrote:
Tue Aug 29, 2017 5:01 am
what ccx version do you use?
I dont know what ccx stand for, for the other answers I suppose it means 'calculix', well I am using the one it come with FreeCAD, I don't know how to change this software or verify the version.
Ok, I do not know which ccx version the 0.17 FreeCAD has, but I download other ccx exe file and use them, the better results are given by 'ccx_2.10_MT' for Windows build, so don't know if it better or not, but know is showing only one result and not several has before (although the values are different from the example image 'abs displacement max' equal to '30.08mm' vs '46.2847mm'; P: 100MPa).
@UR_ I will check your answers, there are some topics I do not understand/manage, so I need to check the information with careful. I was understanding there was some formulation issues with the example, since the other file do work (despite the many result answers)
Thank you so much for the help
polymer
Postby polymer » Fri Dec 22, 2017 5:58 pm
Hello, how is the current state of contact simulation in FreeCAD?
Does it work in the more recent versions with the calculix and elmer solver or is this function not implemented yet?
What is the best workflow for usage, for example when importing a step assembly or a multi-object?
Kind regards
bernd
Postby bernd » Fri Dec 22, 2017 7:14 pm
Kind regards
Best work flow is start with a simple geometry and do some contact simulations with FreeCAD. Afterwards you will have a feeling and have may be a better own background to decide if it fits your needs.
Bernd
makkemal
Postby makkemal » Wed Jan 03, 2018 9:58 am
I have not used this in a while
Still works fine on latest master
I attache example based on latest master
Regards
Michael
Beam_contact.FCStd
(71.42 KiB) Downloaded 97 times
makkemal
Postby makkemal » Wed Oct 03, 2018 12:17 pm
I am working on auto contact feature
I get the following error when applying the Faces with command
App::Document::_RecomputeFeature(): Unknown exception in Feature "FemConstraintContact" thrown
I cant figure out what is going wrong ?
 obj.References = [(geom,face1), (geom,face2)]
Full script below
import FreeCADGui, FreeCAD
import numpy as np
locations = []
#Variables
num=3 # Number of nearest neigbours to found
Slope = 1000000.000000  # Contact stiffness
Friction = 0.300000     # Friction
Scale = 1   # Scale
def find_index_of_nearest(array, idx,num ):
    xpoint=array[idx,0]
    ypoint=array[idx,1]
    zpoint=array[idx,2]
    distance = []
    for i in range(array.shape[0]):
        distance.append((array[i,0]-xpoint)**2 + (array[i,1]-ypoint)**2+ (array[i,2]-zpoint)**2)
    idxmin = np.argpartition(np.array(distance), num)
    idxmin=np.array(idxmin[0:num])
    idxmin=np.delete(idxmin,np.where(idxmin==idx))
    return idxmin
def get_all_close_surfaces(array, num):
    store = []
        store.append(find_index_of_nearest(array,i,num))
    return store
def addcontactobjects(array,geom):
    [col,row]=np.array(array.shape)
    for i in range(array.size):
        #print(i)
        FreeCAD.activeDocument().addObject("Fem::ConstraintContact","FemConstraintContact")
    idxc=0
    idxr=0
    for obj in FreeCAD.ActiveDocument.Objects:
        if (obj.isDerivedFrom('Fem::ConstraintContact')):
            objName = obj.Name
            #print(objName)
            obj.Slope = Slope
            obj.Friction = Friction
            obj.Scale = Scale
            face1='Face'+str(idxc)
            print(face1)
            face2='Face'+str(array[idxc,idxr])
            print(face2)
            print(idxc,array[idxc,idxr])
            idxr+=1
            if idxr > row-1:
                idxr = 0
                idxc+=1
try:
    for obj in FreeCAD.ActiveDocument.Objects:  # seach all objects in document
        objName = obj.Name
        objLabel = obj.Label
        try:
            if obj.Shape.Faces:  # is a face then
                print( objLabel, objName, len(obj.Shape.Faces), " face(s)")
                FreeCADGui.Selection.addSelection(FreeCAD.ActiveDocument.getObject(obj.Name))  # select the object with face
                if 'Compound' in objName:
                    print('Getting vector list for nearest neighbours contact \n ', objName)
                    for face in range(len(obj.Shape.Faces)):  # list the face(s) of object
#                         print(face)
                         surfaceloc=np.array(obj.Shape.Faces[face].CenterOfMass)  # center point
                         locations.append(surfaceloc)
#                         print(surfaceloc)
                    locations = np.array(locations)
                    #print(locations.shape)
                    results = np.array(get_all_close_surfaces(locations,num))
                    print(results)
                    addcontactobjects(results,obj)
                else:
                   print("No object found to apply contact ",objName)
        except Exception:
            print("Not Shape")
except Exception:
    print("Not object")
Regards
Michael
contact_test.FCStd
(8.94 KiB) Downloaded 37 times
bernd
Postby bernd » Wed Oct 03, 2018 6:15 pm
I have an idea, but I do not have access to FreeCAD atm. BTW do you know these links in the regard of contactFEM_ConstraintContact
bernd
Postby bernd » Fri Oct 05, 2018 5:08 am
Could you give more informations what your problem is?
What I did:
- open your file
- run your code
- no error
- 36 Contact constraints are added to the document
makkemal
Postby makkemal » Fri Oct 05, 2018 9:42 am
Version: 0.18.14893 (Git)
Hash: b8c50dc0f93410d1a8009a162385b50107c301ec
Python version: 2.7.8
OCC version: 7.0.0
Locale: English/SouthAfrica (en_ZA)
Only faces are applied to first contact constraint if you open the contact and close it it gives the error even though the faces are valid ?
