MKS units
Fernando
MKS units
Postby Fernando » Mon May 16, 2016 12:45 pm
I'm trying to build the 3d model of a 2 stores house project I'm working. I import the autocad plans and set the units to mks. I noticed that most of the units are still displayed as mm, Including the default settings in the arch preferences, the measurement objects, etc. The behavior of the wall command is very strange, leading to 30 Km tall walls.
my question is: How do you use to set your units for architectural modeling (the way you think it works better)?
Renato Rebelo
Re: MKS units
Postby Renato Rebelo » Mon May 16, 2016 3:34 pm
Welcome
I use the same settings that you, and I think this is the correct way, but they are known certain inconsistencies in different parts of the program on the subject
Renato Rebelo
my native language is not English, please excuse me any incorrectness, I apologize for any inconvenience caused, thank you
bernd
Re: MKS units
Postby bernd » Tue May 17, 2016 1:01 pm
In the regard of a 30 km wide wall you could have a look at this post and the following post. Both solutions have been worked for me. viewtopic.php?f=23&t=13581&start=10#p117644
FYI: internally FreeCAD uses mm in any case (AFAIK). The unit system does make it possible to use other units to put in and get out of FreeCAD. They are converted by FreeCADs unit system which does not work in any case as espected. In german locale this is in most cases due to the comma we use as dezimal separator instead of a point.
Fernando
Re: MKS units
Postby Fernando » Sat May 28, 2016 12:25 am
Thanks a lot Renato and Brend, I could figure out how to work based on yours replies.
Dimensions are a tricky thing in a lot of cad systems. Especially in the AEC industries, where different professionals use different units. You can't convince an architect to work in millimeters, or a structural drafter to work in meters. And there are good reasons for that. I've worked in both positions along time and there were communication problems regarded to file dimensions and Autocad xrefs here and there.
In my opinion there should be a way for all the professional to choose the most coherent unit of work without any inconvenient behavior regarding the units used by the other members of the team. But I assume there are already a lot of discussion and ideas on the topic.
yorik
Site Admin
Re: MKS units
Postby yorik » Sun May 29, 2016 11:52 pm
I recently added a new units scheme that displays all measurements in centimeters, no matter the size. The current MKS system switches from one unit to another depending on the size. Maybe we need one more that forces everything in meters.
About the comma/period problem, another thing I noticed is that the displayed distance is constructed using the Qt default thousands and decimal separators. We could test a unit system that doesn't use that (for ex. always uses a period). If it works, then it would actually be easy to abstract into a preference setting...
