Custom template not usable as page
francoislark
Postby francoislark » Mon Jun 06, 2016 12:03 am
I created a custom template following the tutorial Drawing_Template_HowTo with Inkscape.
Adding this template in Freecad Templates directory didn't make it available in the drop-down list of the Drawing Workshop.
I could open the template with the button "open a svg file" but found no way to make it appear as a page in the tree, and I couldn't use it to create drawing views nor projections of my model.
I tried to use the US_Legal_ds_Landscape.svg file which I found on the FreeCAD website, and it didn't work either.
Is there a way to import US formats in the Drawing Workshop?
bejant
Re: Custom template not usable as page
Postby bejant » Mon Jun 06, 2016 1:32 pm
francoislark wrote:I created a custom template following the tutorial Drawing_Template_HowTo with Inkscape.
Hi francoislark, is this the tutorial you used?
http://www.freecadweb.org/wiki/index.ph ... late_HowTo
General info:
http://www.freecadweb.org/wiki/index.ph ... _templates
francoislark wrote:Adding this template in Freecad Templates directory didn't make it available in the drop-down list of the Drawing Workshop.
francoislark wrote:I tried to use the US_Legal_ds_Landscape.svg file which I found on the FreeCAD website, and it didn't work either.
Yes, maybe these links will help you:
viewtopic.php?t=11628
https://github.com/quick61/FreeCAD-Draw ... s/issues/2
wandererfan
Postby wandererfan » Mon Jun 06, 2016 1:47 pm
Drawing Module only lists templates with a filename that matches this regular expression: "(A|B|C|D|E)(\\d)_(Landscape|Portrait)(_.*\\.|\\.)svg$", so "US_Legal_ds_Landscape.svg" would never appear in the list. You could maybe try "B4_Landscape_US_Legal.svg" to fiddle the system?
wf
francoislark
Postby francoislark » Mon Jun 06, 2016 2:45 pm
@wanderfan
With the new name B4_Landscape_US_Legal.svg the template appear in the list and is selectable.
I can edit the editable texts.
Thank you.
I didn't explore the other hints yet.
francoislark
Postby francoislark » Mon Jun 06, 2016 3:37 pm
@bejant
Yes, these were the tutorial and general info I used.
I found the links you gave very informative.
I was able to create my drawing with dimensions following the video https://www.youtube.com/watch?v=nxNT0KychcY in a B4 legal US format.
The only thing I miss, is how to create a dimension for an angle.
Thank you for your help!
tantle1961
Postby tantle1961 » Tue Feb 28, 2017 3:57 pm
I was playing around with custom templates and found this thread. I was able to create my own SVG file.
Can my drawings be used with my custom templates? When I add an object, it always goes to the default A3 page.
OS: Windows 8.1
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
TA3_Template.svg
(26.92 KiB) Downloaded 83 times
Bathtub_Drawing.FCStd
(122.04 KiB) Downloaded 14 times
mario52
Postby mario52 » Wed Mar 01, 2017 10:04 am
hi
rename your template A3_Landscape_TA3.svg and move it in C:\Program Files\FreeCAD 0.16\data\Mod\Drawing\Templates
in FreeCAD select your file in "Insert new drawing" Image
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
tantle1961
Postby tantle1961 » Fri Mar 03, 2017 11:34 pm
Very nice! Thank you very much.
tantle1961
Postby tantle1961 » Sat Mar 04, 2017 5:57 am
I used your suggestion a couple of times and it worked like a charm... then I got this error ... or did I do something wrong?
1) Created the SVG file and named it as suggested. This worked
SVG file name in Windows explorer
SVG file.jpg (19.52 KiB) Viewed 1166 times
2) I selected a drawing template from my new menu. This worked
3) Then, another drawing... same as before but got this error. Notice the "TA32" in the file name. The file is "TA3.SVG". Is this a bug or did I do something to trigger it? This is a repeat from an earlier attempt. The first one was TA31 but I failed to get screenshot of it.
FreeCAD error message
TA32 error.jpg (23.43 KiB) Viewed 1166 times
OS: Windows 8.1
FreeCAD menu selection
TA3 menu.jpg (14.1 KiB) Viewed 1166 times
triplus
Postby triplus » Sat Mar 04, 2017 1:03 pm
Hi @tantle1961.
It looks like a different error but note that inserting more than 1 drawing template of the same type will result in issues after. When you reopen the file and recompute operation occurs. This is one of the known issues in FreeCAD 0.16. In addition you used custom drawing template therefore if you use FreeCAD on 2 computers the file won't work correctly on another if you don't provide the custom template there. Some of this was fixed in FreeCAD 0.17 and TechDraw (new drawing related workbench in FreeCAD 0.17) does this differently.
P.S. My recommendation would be use one drawing template of the same type per file and when you are done export to SVG and/or print to PDF.
