make faces from edges
bernd
Post by bernd »
I have a bound of edges. I would like to get faces from them by python. but I do not know which edges gone make a face. I just have a bound of edges and for sure they build valid faces. Attached a sample edge file and a screen of the colored (the color is just for better showing) faces I would like to archive.
edges.fcstd
(18.3 KiB) Downloaded 38 times
DeepSOIC
Re: make faces from edges
Post by DeepSOIC »
microelly2
Post by microelly2 »
Some fun:
convert to gray -> invert -> threshold/morphing -> skeleton
faces are "not connected" components of the skeleton.
because the edges disconnect them.
Still not implemented (but a goal of the reconstruction wb): backward from skeleton to face: :geek:
bernd
Post by bernd »
I had to play a bit to find how it works in the gui ...
- Part --> Shape builder --> Make a big Face from all outer edges
- Part --> Fuse all edges to a wire
- Part --> Extrude the wire --> the result will be one non-manifold shell
- Part --> Cut The big outer Face and the non-manifold shell --> the result will be a compound of the faces
Perfect !
BTW:
My own idea was exactly the walking one with the lowest clock angle. But I thought I may ask before I start. Very good idea indeed.
@microelly2: nice one
wandererfan
Post by wandererfan »
Does this method always work, or have I missed a step? Macro works great with one set of points, but not the second.
2DCutResult.fcstd
(9.25 KiB) Downloaded 46 times
2DCut.py.zip
Not really a zip file.
(2.48 KiB) Downloaded 58 times
OS: Ubuntu 12.04.5 LTS
Version: 0.17.7689 +86 (Git)
Build type: debug
Branch: FaceDetect
Hash: 21c8c5b2e68319a9758330b8611d1a7a18594440
Python version: 2.7.3
Qt version: 4.8.1
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17-dev
DeepSOIC
Post by DeepSOIC »
wandererfan wrote:Does this method always work, or have I missed a step? Macro works great with one set of points, but not the second.
I looked at the shapes in the project. The cutting shell in the case that fails is actually a compound of two shells. I disassembled it and fused it back together (Lattice Downgrade to faces, then Lattice Fuse Compound). Then the cut worked.
I'll take a look at your macro later...
DeepSOIC
Post by DeepSOIC »
Fixed script:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
# tester for 2D cutting per DeepSOIC's method
import FreeCAD
import Part
org = FreeCAD.Vector(0,0,0)
zDir = FreeCAD.Vector(0,0,1)
xDir = FreeCAD.Vector(1,0,0)
xtr = FreeCAD.Vector(0,0,5)
xlate = FreeCAD.Vector(-100,-100,0)
#v0 = FreeCAD.Vector(0.0,0.0,0.0)      #these points work
#v1 = FreeCAD.Vector(-10.0,-10.0,0.0)
#v2 = FreeCAD.Vector(-10.0,10.0,0.0)
#v3 = FreeCAD.Vector(10.0,10.0,0.0)
#v4 = FreeCAD.Vector(10.0,-10.0,0.0)
v0 = FreeCAD.Vector(-50.000,-10.000,0.000) #these points do not.  order?
v0a = FreeCAD.Vector(-30.00,-10.000,0.000)
v1 = FreeCAD.Vector(30.000,-10.000,0.000)
v1a = FreeCAD.Vector(50.00,-10.000,0.000)
v2 = FreeCAD.Vector(-50.000,10.000,0.000)
v2a = FreeCAD.Vector(-50.00,-10.000,0.000)
v3 = FreeCAD.Vector(50.000,10.000,0.000)
v3a = FreeCAD.Vector(50.00,-10.000,0.000)
v4 = FreeCAD.Vector(-50.000,30.000,0.000)
v4a = FreeCAD.Vector(50.00,30.000,0.000)
v5 = FreeCAD.Vector(-50.000,30.000,0.000)
v5a = FreeCAD.Vector(-50.00,10.000,0.000)
v6 = FreeCAD.Vector(50.000,30.000,0.000)
v6a = FreeCAD.Vector(50.00,10.000,0.000)
v7 = FreeCAD.Vector(-10.000,-30.000,0.000)
v7a = FreeCAD.Vector(10.00,-30.000,0.000)
v8 = FreeCAD.Vector(-50.000,10.000,0.000)
v8a = FreeCAD.Vector(-30.00,-10.000,0.000)
v9 = FreeCAD.Vector(-30.000,-10.000,0.000)
v9a = FreeCAD.Vector(-10.00,-30.000,0.000)
v10 = FreeCAD.Vector(50.000,10.000,0.000)
v10a = FreeCAD.Vector(30.00,-10.000,0.000)
v11 = FreeCAD.Vector(30.000,-10.000,0.000)
v11a = FreeCAD.Vector(10.00,-30.000,0.000)
#e = []
#e.append(Part.makeLine(v0,v1))
#e.append(Part.makeLine(v1,v2))
#e.append(Part.makeLine(v2,v0))
#e.append(Part.makeLine(v1,v3))
#e.append(Part.makeLine(v3,v4))
#e.append(Part.makeLine(v4,v1))
e.append(Part.makeLine(v0,v0a))
e.append(Part.makeLine(v1,v1a))
e.append(Part.makeLine(v2,v2a))
e.append(Part.makeLine(v3,v3a))
e.append(Part.makeLine(v4,v4a))
e.append(Part.makeLine(v5,v5a))
e.append(Part.makeLine(v6,v6a))
e.append(Part.makeLine(v7,v7a))
e.append(Part.makeLine(v8,v8a))
e.append(Part.makeLine(v9,v9a))
e.append(Part.makeLine(v10,v10a))
e.append(Part.makeLine(v11,v11a))
wire = e[0].multiFuse(e[1:])
shell = wire.extrude(xtr)    #extrude -> makePrism -> BRepPrimAPI_MakePrism
Part.show(shell)
p = Part.makePlane(200,200)
p.translate(xlate)
Part.show(p)
result = p.cut(shell)
Part.show(result)
The problem was in attempting to make a non-manifold shell with Part.makeShell. It is known to not work (I think it was discovered by @bernd in his attempts to do FEM on compsolids).
So:
first, fuse edges into a wire (I think using Part.makeWire will not work too, but I didn't test)
second, extrude the wire (yields a shell, or compound of shells)
third, cut the face with shell. Done.
bernd
Post by bernd »
DeepSOIC wrote:The problem was in attempting to make a non-manifold shell with Part.makeShell. It is known to not work (I think it was discovered by @bernd in his attempts to do FEM on compsolids).
So:
Exactly:
Neiter Part.makeWire with edges, nor Part.makeShell with face or Part.makeCompSolid with solids make valid non-manifold solids. For edges and faces the Part.fuse could be used (wink to DeepSOIC :D ) instead.
bernd
Post by bernd »
attached my code and file ...
edges = []
for o in App.ActiveDocument.Objects:
    if o.Shape.ShapeType == 'Edge':
        edges.append(o.Shape)
fusion_wire = edges[0]
for no, e in enumerate(edges):
    no += 1
    if no > 1:
        fusion_wire = fusion_wire.fuse(e)
ex = fusion_wire.extrude(FreeCAD.Vector(0,0,5))
FreeCAD.ActiveDocument.recompute()
slab = App.ActiveDocument.Face.Shape.cut(ex)
for f in slab.Faces:
    Part.show(f)
edges-and-face.fcstd
(19.71 KiB) Downloaded 41 times
bernd
Post by bernd »
Next problem to solve ...
I have a vertex and would like to know on which face the vertex is. The vertex is inside of one of the faces and on the plane of the faces.
