New Module for Technical Drawings (TechDraw)
wandererfan
Postby wandererfan » Mon Jul 11, 2016 5:11 pm
TechDraw was merged to master today. Thanks to everybody who helped get TechDraw to this point and especially to Luke who started it all.
A preliminary wiki page can be found here: TechDraw_Module
Background on the module is here: https://github.com/WandererFan/FreeCAD-TechDraw/wiki
Current bug list is here: https://github.com/WandererFan/FreeCAD-TechDraw/issues We willl move to Mantis shortly.
Note that some people are still having problems building FreeCAD with TechDraw. Please report any build problems in the Install/Compile forum.
As it says on the wiki page: "TechDraw is very much still in development. You should expect bugs!"
wf
blacey
Re: New Module for Technical Drawings (TechDraw)
Postby blacey » Mon Jul 11, 2016 5:51 pm
Great work guys! TechDraw is a really nice addition and clearly represents a lot of impressive work by those involved. As a result of the merge, we now have our first FreeCAD/FreeCAD macOS / OS X build that includes TechDraw available on the FreeCAD Github repo.
Any macOS / OS X build in the GitHub releases section that is commit 7957 or later includes TechDraw.
OS: Mac OS X
Version: 0.17.7957 (Git)
Branch: (detached from 2ac560e)
Hash: 2ac560e7b027590e8d6b534b84020d4c1624ece5
Python version: 2.7.12
Coin version: 3.1.3
OCC version: 7.0.0
wandererfan
Postby wandererfan » Mon Jul 11, 2016 6:45 pm
I just built from master with no problems for this environment:
OS: Ubuntu 12.04.5 LTS
Build type: debug
Python version: 2.7.3
Qt version: 4.8.1
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
boost v1.55
g++ v4.9
cmake 3.2.3
HDF5 6.0.3
MedC 1.2.4
netgen 4.9.13
opengl -> mesa/libGL 1.2.0
swig 2.0
shiboken 1.1.0
vtk 6.3.0
and Mark has build it on Kubuntu 14.04 viewtopic.php?f=27&t=16365&start=50#p130593
triplus
Postby triplus » Mon Jul 11, 2016 7:48 pm
Technical drawing is one of the cornerstones of any creative process. FreeCAD now has a straightforward solution to achieve exactly that.
Thanks to all involved over the years for achieving this!
wandererfan
Postby wandererfan » Mon Jul 11, 2016 11:37 pm
TechDraw in master also builds and runs with OCC7. Same support libraries as last post.
Build type: debug
Qt version: 4.8.1
Coin version: 3.1.3
OCC version: 7.0.0
chakkree
Postby chakkree » Tue Jul 12, 2016 5:16 am
I insert SVG file(Export from DWG file) to TechDraw and set scale property, result as Fig.1
Then close file and re-open that result as Fig.2
I'm fixed this problem by python macro
for obj in FreeCAD.ActiveDocument.Page001.Views:
    obj.touch()
FreeCAD.ActiveDocument.recompute()
Overall, is very good. I can move each image by dragging.
Test_insertSVG.FCStd
(305.6 KiB) Downloaded 116 times
Python version: 2.7.8
OCC version: 7.0.0
Renato Rebelo
Postby Renato Rebelo » Tue Jul 12, 2016 9:14 am
I have been testing and it works very well, but as an architect I usually use the arch section plan to generate views, and this does not work yet, there are plans to include this feature?
thank you
Renato Rebelo
my native language is not English, please excuse me any incorrectness, I apologize for any inconvenience caused, thank you
wandererfan
Postby wandererfan » Tue Jul 12, 2016 11:50 am
chakkree wrote:I insert SVG file(Export from DWG file) to TechDraw and set scale property, result as Fig.1
Thanks for reporting. https://github.com/WandererFan/FreeCAD- ... /issues/59 added.
Clever work-around with the python code.
wf
wandererfan
Postby wandererfan » Tue Jul 12, 2016 11:54 am
Renato Rebelo wrote: as an architect I usually use the arch section plan to generate views, and this does not work yet, there are plans to include this feature?
The current "Draft View" function is a placeholder https://github.com/WandererFan/FreeCAD- ... w/issues/5.
I'm not very familiar with Arch, but the plan is to include everything.
wf
yorik
Site Admin
Postby yorik » Tue Jul 12, 2016 7:04 pm
Congrats guys, amazing work!!!
I can help with Draft View if you want wandererfan, just call if needed
