Material improvements
A forum to discuss the implementation of a good Materials system in FreeCAD
eivindkvedalen
Re: Material improvements
Postby eivindkvedalen » Fri Sep 06, 2019 7:07 pm
bernd wrote:
Wed Aug 28, 2019 10:45 am
:) wow which branch on https://github.com/eivindkv/FreeCAD? On Py2 or Py3?
How about this ?
eivindkvedalen wrote:
Tue Apr 02, 2019 6:54 pm
bernd wrote:
Tue Apr 02, 2019 5:16 pm
with Python2 and Qt5 I am able to compile this branch. But as soon as an object which has a Shape property is created FreeCAD crashes. Files with meshes or for example an FEM file without the shape saves and reopens fine.
I discovered that as well, and I'm looking into it now...
Eivind
I haven't had time to clean up and push anything. I'll see if I get time to at least push something this weekend.
Eivind
bernd
Postby bernd » Fri Sep 06, 2019 8:20 pm
8-)
Postby Kunda1 » Sat Nov 09, 2019 12:37 pm
Related:
bernd
Postby bernd » Sun Jan 05, 2020 10:00 pm
Fri Aug 23, 2019 6:05 pm
bernd wrote:
Mon Aug 19, 2019 5:21 am
The big App::Link merge has taken place. On rebase I get merge conflicts in a few files:
       von beiden geändert:    src/App/DynamicProperty.cpp
        von beiden geändert:    src/App/DynamicProperty.h
        von beiden geändert:    src/App/Property.h
        von beiden geändert:    src/App/PropertyExpressionEngine.cpp
        von beiden geändert:    src/App/PropertyStandard.cpp
        von beiden geändert:    src/Mod/Spreadsheet/App/Cell.cpp
If you are still on this it might makes sense to rebase to up to date master.
I managed to compile it on a rebased master today.
Eivind
... I haven't had time to clean up and push anything. I'll see if I get time to at least push something this weekend.
Eivind
Reminder.
bernd
Postby bernd » Mon Jan 20, 2020 8:58 pm
eivind ...
would you make your latest dev public?
realthunder
Postby realthunder » Thu Feb 27, 2020 4:42 am
I didn't go through this entire thread. I jumped from here. Just to clarify some related issue about map accessing. The linked post uses Python code injection for map key retrieval, which has been removed during the big merge for obvious security reason. The current expression parser supports similar list/slice/map accessing syntax as Python. And it accepts expression as index or key. For example, the code in the linked post can be changed to (assuming 'Density' is a property of the current object)
Panel014.Material.Material[.Density]
It can even be shortened to the following with some small modification to the 'Material' property (I don't know what type exactly), similar to the modification here to sketch's PropertyConstraintList.
Panel014.Material[.Density]
eivindkvedalen
Postby eivindkvedalen » Tue Mar 03, 2020 8:44 pm
eivind ...
Something rebased on current master that compiles, but lacking both testing and features: https://github.com/eivindkv/FreeCAD/tre ... al_rebased
Eivind
bernd
Postby bernd » Wed Mar 04, 2020 9:42 am
very cool :) just gave it a try ...
had a compile error on gcc on linux debian buster ...
hugo@Ahorn:~/build$ make
[  0%] Built target MEFISTO2
[  1%] Built target SMDS
[  1%] Built target SMESHDS
[  1%] Built target Driver
[  2%] Built target DriverSTL
[  2%] Built target DriverDAT
[  2%] Built target DriverUNV
[  3%] Built target SMESH
[  5%] Built target StdMeshers
[  8%] Built target FreeCADBase
[  9%] Generating version_check
git
/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/src/Build/Version.h.out written
[  9%] Generating Version.h
[  9%] Built target fc_version
[  9%] Building CXX object src/App/CMakeFiles/FreeCADApp.dir/MaterialDatabase.cpp.o
/home/hugo/Documents/dev/freecad/freecadbhb_dev/freecad/src/App/MaterialDatabase.cpp: In static member function ‘static boost::any App::MaterialDatabase::python2string(const PyObject*)’:
/home/hugo/Documents/dev/freecad/freecadbhb_dev/freecad/src/App/MaterialDatabase.cpp:150:26: error: ‘PyString_AsString’ was not declared in this scope
     std::string string = PyString_AsString(unicode);
/home/hugo/Documents/dev/freecad/freecadbhb_dev/freecad/src/App/MaterialDatabase.cpp:150:26: note: suggested alternative: ‘PyBytes_AsString’
                          PyBytes_AsString
make[2]: *** [src/App/CMakeFiles/FreeCADApp.dir/build.make:728: src/App/CMakeFiles/FreeCADApp.dir/MaterialDatabase.cpp.o] Fehler 1
make[1]: *** [CMakeFiles/Makefile2:789: src/App/CMakeFiles/FreeCADApp.dir/all] Fehler 2
make: *** [Makefile:130: all] Fehler 2
hugo@Ahorn:~/build$
eivindkvedalen
Postby eivindkvedalen » Wed Mar 04, 2020 7:54 pm
Probably a python 2/3 issue. I've made a change so please pull the branch again.
Eivind
bernd
Postby bernd » Fri Mar 06, 2020 11:52 am
done. compiles on Debian Buster with Py3, but on startup ...
hugo@Ahorn:~/Documents/dev/freecad/freecadbhb_dev/build$
hugo@Ahorn:~/Documents/dev/freecad/freecadbhb_dev/build$ ./bin/FreeCAD
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x37840) [0x7f076e0e0840]
#1  /lib/x86_64-linux-gnu/libpython3.7m.so.1.0(PyTuple_New+0xf7) [0x7f0770969fb7]
#2  /lib/x86_64-linux-gnu/libpython3.7m.so.1.0(PyType_Ready+0x1ab2) [0x7f07707cab62]
#3  /lib/x86_64-linux-gnu/libpython3.7m.so.1.0(PyType_Ready+0x1ee8) [0x7f07707caf98]
#4  0x7f0771367f6e in Py::PythonType::readyType() from /home/hugo/Documents/dev/freecad/freecadbhb_dev/build/lib/libFreeCADBase.so+0x1c
#5  0x7f0772115d0b in Py::SolidMaterialArray::init_type() from /home/hugo/Documents/dev/freecad/freecadbhb_dev/build/lib/libFreeCADApp.so+0x46
#6  0x7f07721157b4 in Py::PropertyPartMaterial::init_type() from /home/hugo/Documents/dev/freecad/freecadbhb_dev/build/lib/libFreeCADApp.so+0x16
#7  0x7f077216aa71 in App::Application::initTypes() from /home/hugo/Documents/dev/freecad/freecadbhb_dev/build/lib/libFreeCADApp.so+0x1ff
#8  0x7f077216a82d in App::Application::init(int, char**) from /home/hugo/Documents/dev/freecad/freecadbhb_dev/build/lib/libFreeCADApp.so+0x35
#9  ./bin/FreeCAD(main+0x6ef) [0x556880aa3d29]
#10  /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xeb) [0x7f076e0cd09b]
#11  ./bin/FreeCAD(_start+0x2a) [0x556880aa34ca]
