TechDraw Fixes & Enhancements #230
Merged, abandoned or rejected pull requests are moved here to clear the main Pull Requests forum.
wandererfan
Postby wandererfan » Mon Aug 01, 2016 3:09 pm
Please merge: https://github.com/FreeCAD/FreeCAD/pull/230
It addresses the following:
Fix scaling for ViewSymbol
Correct page size determination
Fix 2630 lines in SVG
Add linewidth property for Dimensions
Qt parenting/garbage collection
Radius leader behaviour
Thanks,
wf
yorik
Site Admin
Re: TechDraw Fixes & Enhancements #230
Postby yorik » Mon Aug 01, 2016 10:30 pm
merged!
efyx
Postby efyx » Tue Aug 02, 2016 8:08 am
I wrote some suggestions here: viewtopic.php?f=9&p=132940#p132940 but I'll put some thoughts here.
First wandererfan good job! :mrgreen:
I think you should take a lot of "drawing dimensioning" because there are a lot of stuff which is performed very well for example:
- higlighting edges and vertexes on green (better chance to select the right one),
- one dimension tool and first you select tool then edges/vertexes - you drag it into direction and you have horizontal/vertical dimension btw. in techdraw also one dimension tool works for all dimensions - so rest icon's aren't necessary. Just to change order, first icon of action then edges/vertexes,
- very good creating center lines in "drawing dimensioning",
- very good creating center points,
- good performance of tolerances (should be more options but works cool by later choosing place where to add those tolerances),
What would be very useful in techdraw:
1) Section view - by choosing on view line which will describe place of section and then cuted view.
2) Detail view - that is, a must have :)
3) Automaticly adding scale note for views which aren't in document scale.
4) Tolerances I would see it as in "drawing diemnsioning" but with few addons.
5) Center lines and points as in "drawing dimensioning".
6) Auxiliary views.
7) Welding symbols - we can discuss how they should be created because there a lot of informations.
8) Holes dimensioning - additional icon, to describe fi value of hole and their count (grouping by size on plane) and their depth.
9) Izometric view should have option to be indicated as a preview of object - not just a wire lines.
10) Navigation on drawing page shoul be also on left/right/up/down not only scroll down and up, because sometimes you need to perform some part of drawing which is no visible outside border of drawing - for example just for detail view.
PS. merged? Is that means that it is available in the newest 0.16 instalator? Or there is need to compile freecad from git?
Jee-Bee
Postby Jee-Bee » Tue Aug 02, 2016 10:08 am
efyx wrote:PS. merged? Is that means that it is available in the newest 0.16 instalator? Or there is need to compile freecad from git?
Nope the next 0.17 builds
efyx
Postby efyx » Tue Aug 02, 2016 10:45 am
Jee-Bee wrote:Nope the next 0.17 builds
Is that means, that this will be soon available for windows here?: https://github.com/FreeCAD/FreeCAD/releases
Jee-Bee
Postby Jee-Bee » Tue Aug 02, 2016 11:45 am
i think it should there all ready don't know all you're comments but TechDraw should there...
triplus
Postby triplus » Tue Aug 02, 2016 12:32 pm
efyx wrote:I wrote some suggestions here: viewtopic.php?f=9&p=132940#p132940 but I'll put some thoughts here.
6) Auxiliary views.
Hi @efyx.
This thread was made for such comments:
viewtopic.php?f=8&t=16831
