FreeCAD pip and get python packages into the FreeCAD python ecosystem
easyw-fc
Postby easyw-fc » Wed Aug 03, 2016 8:35 am
with the latest ssl support, it easy to get pip
https://bootstrap.pypa.io/get-pip.py
and install pip on FC locally
C:\FreeCAD_0.17\bin\python get-pip.py
then get python packages installed locally into the FreeCAD python ecosystem
cd C:\FreeCAD_0.17\bin\
C:\FreeCAD_0.17\bin\Scripts\pip install <pkg_name>
In windows this is giving a fully python local environment, that can be called internally in FC or externally as for your needs.
To be tested in Linux and OSX to see if that could break any dependencies
Maurice
reference:
viewtopic.php?f=4&t=16163&p=133142#p133129
sgrogan
Re: FreeCAD pip and get python packages into the FreeCAD python ecosystem
Postby sgrogan » Thu Mar 01, 2018 10:11 pm
How do you call this internally, from the Python console?
"fight the good fight"
easyw-fc
Postby easyw-fc » Fri Mar 02, 2018 6:26 pm
I meant that when you install a new python package using pip outside FreeCAD, the package is going to be installed in a way that makes it compatible to run later inside FreeCAD...
looo
Postby looo » Fri Mar 02, 2018 6:37 pm
this works for the simple (python only) packages. But this can fail for more difficult packages with compiled binaries (numpy, scipy,...) .
Pip is directly shipped with python3. So best is to push for python3 to get a more consistent environment for windows.
sgrogan
Postby sgrogan » Fri Mar 02, 2018 6:58 pm
I figured out you can do
import pip
pip.main(['install'] + ['<package_name>']
from an external python console, but it doesn't work in the FreeCAD python console.
But this only improves things if the whole libpack is ported to VC14. The same problem would exist if I upgraded to PY3 and compiled with VS2013(VC12).
looo
Postby looo » Fri Mar 02, 2018 8:10 pm
for sure. But vs2013 + py3 make no sense at all I guess.
