Part Revolve parametric axis link
DeepSOIC
Postby DeepSOIC » Tue Aug 09, 2016 10:28 am
Since 0.17.8172, Part Revolve can use arbitrary line or edge from the model as revolution axis, and establish parametric link to it.
The edge can be a line, or a circle/arc. If arc of circle, and angle of Revolve is set to zero, the angle span of the arc is used.
Also, symmetric option was added (functions like PartDesign's Symmetric to plane).
Enjoy ;)
ezzieyguywuf
Re: Part Revolve parametric axis link
Postby ezzieyguywuf » Wed Aug 10, 2016 1:26 pm
Nicely done!
f3nix
Postby f3nix » Wed Aug 31, 2016 8:44 pm
Thanks DeepSOIC! :)
I wanted to give it a try but it seems that the layout of the task panel is broken for me.
The spinboxes are too small. I'm using KDE.
OS: Debian GNU/Linux unstable (sid)
Version: 0.17.8318 (Git)
Build type: Debug
Hash: ff2ccdd64852c0c6b2066ed439e2b2a3d53d842b
Python version: 2.7.12+
OCC version: 7.0.0
Cheers,
Mateusz
DeepSOIC
Postby DeepSOIC » Wed Aug 31, 2016 10:40 pm
f3nix wrote:that the layout of the task panel is broken for me.
Oh, how was I supposed to know....
That Qt designer... I hate it.
Can you fix it, pleease? :roll: That probably applies to reworked Part Extrude dialog that is now stuck in pull requests...
triplus
Postby triplus » Wed Aug 31, 2016 10:49 pm
And after so much time invested in all the Tasks sidebar related things! ;)
f3nix
Postby f3nix » Thu Sep 01, 2016 8:24 pm
Hi.
I've attached a patch that fixes it for me. Hopefully it does not break anything on other platforms. Please give it a try.
Thanks again for these new tools! :)
Cheers,
Mateusz
Some screenshots.
Revolve
Before
After
Extrude
Before
After
layout_fix.patch.bz2
(2.17 KiB) Downloaded 23 times
DeepSOIC
Postby DeepSOIC » Thu Sep 01, 2016 8:51 pm
Thanks f3nix, the layout is still all right on Windows 10.
DeepSOIC
Postby DeepSOIC » Fri Sep 02, 2016 9:10 am
f3nix wrote:I've attached a patch that fixes it for me.
I created a pull-request for it. https://github.com/FreeCAD/FreeCAD/pull/271
I hope you don't mind that the commit bears my authorship. At least I mentioned you ;)
f3nix
Postby f3nix » Sat Sep 03, 2016 12:53 pm
Great! :) No. I do not mind.
Thanks again for your work! :)
Cheers,
Mateusz
