Part Slicing for Foam-Padded Case
ickby
Re: Part Slicing for Foam-Padded Case
Postby ickby » Fri Aug 19, 2016 6:09 am
I had a stupid error in my script. I did not notive it yesterday as I don't run macros in a local environment... here a fixed version. As noted by deepsoic it does not work with occ7 as there are multiple differences. I think this is worth a bugreport and some investigation, at least the multifuse issue must be handled in FreeCAD, such differences should not be accepted.
import Part
#get the shape to slice
shape = Gui.Selection.getSelection()[0].Shape
#parameters
thickness = 2; #thickness of foam
slices = 11;   #number of slices
#needed boiler plate: Bounding box and side faces
bbox = shape.BoundBox;
extbox = Part.makeBox(bbox.XLength*1.2, bbox.YLength*1.2, bbox.ZLength*1.2)
extbox.translate(bbox.Center - extbox.CenterOfMass);
rightFace = extbox.Faces[2]
leftFace = extbox.Faces[3]
for x in range(0, slices):
   #build the foam slice we want to use
   foam = Part.makeBox(thickness, bbox.YLength*1.2, bbox.ZLength*1.2);
   foam.translate(App.Vector(bbox.XMin + bbox.XLength/slices*x, bbox.Center.y - foam.CenterOfMass.y, bbox.Center.z - foam.CenterOfMass.z));
   bface = foam.Faces[0];
   #get the part sections that needs to be handled by that slice
   section = foam.common(shape);
   #we need to handle each solid seperate
   for solid in section.Solids:
      #get the needed largest needed outline by projecting all faces
      projections = [];
      for face in solid.Faces:
         edges = bface.project([face]);
         face = Part.Face(Part.Wire(edges.Edges));
         projections.append(face);
      projection = projections[0].multiFuse(projections);
      Part.show(solid)
      Part.show(projection)
      projection = projection.removeSplitter();
      outline = projection.Faces[0].OuterWire;
      #find the left- and rightmost points in the outline and ensure that we have verices there
      def splitEdges ( outline, dist ):
         if dist[2][0][3] == 'Edge':
            e = outline.Edges[dist[2][0][4]];
            edges = outline.Edges;
            del edges[dist[2][0][4]]
            split = e.split(dist[2][0][5]);
            edges += split.Edges;
            vertex = split.Vertexes[1];
            return (Part.Wire(edges), vertex);
         return (outline, outline.Vertexes[dist[2][0][4]])
      res = splitEdges(outline, rightFace.distToShape(outline));
      v1 = res[1];
      res = splitEdges(res[0], leftFace.distToShape(res[0]));
      v2 = res[1];
      outline = res[0];
      #build extension lines to ensure we cut out the whole foam
      e = [];
      e.append( Part.Edge(Part.Line(v1.Point, v1.Point + App.Vector(0,0,bbox.ZLength))) );
      e.append( Part.Edge(Part.Line(v1.Point + App.Vector(0,0,bbox.ZLength), v2.Point + App.Vector(0,0,bbox.ZLength))) );
      e.append( Part.Edge(Part.Line(v2.Point + App.Vector(0,0,bbox.ZLength), v2.Point)) );
      #find a set of outline edges between the vertices: it doesnt matter which path of the two possibles
      def getNextEdge(edges, vertex):
         for edge in edges:
            if (edge.Vertexes[0].Point - vertex.Point).Length < 1e-4:
               edges.remove(edge);
               return (edge, edge.Vertexes[1]);
            if (edge.Vertexes[1].Point - vertex.Point).Length < 1e-4:
               edges.remove(edge);
               return (edge, edge.Vertexes[0]);
      res = getNextEdge(edges, v2);
      e.append(res[0]);
      while res[0] and ((res[1].Point - v1.Point).Length > 1e-4):
         res = getNextEdge(edges, res[1]);
         e.append(res[0]);
      #we are not sure we have build the real outer wire, we could have followed the wrong edge... brute forece again!
      face = Part.Face(outline).fuse(Part.Face(Part.Wire(e)));
      #build the cut shape and finaly cut the foam
      hole = face.extrude(App.Vector(thickness, 0 ,0));
      foam = foam.cut(hole).removeSplitter();
   Part.show(foam)
I added a bug report to ensure this is not forgotten: issue #0002676
Spida
Postby Spida » Fri Aug 19, 2016 11:30 pm
ickby wrote:this script should work and hold all your constraints.
Thank you very much for your work, the script looks like it will do exactly what I need.
Sadly, the script does not seem to work on my file.
Issues I found:
  • Using a comparison on
    (Point1 - Point2).Length
    to get a distance seems to fail in case both points are coincident.
    Point1.distanceToPoint(Point2)
    seems to cover that corner case better, though.
  • Fixing these, I get the following error when I run the script:
      File "script.py", line 36, in <module>
    <class 'Part.OCCError'>: BRep_API: command not done
    As far as I understand, the root cause here is similar: points that should have been connected by an edge are coincident, so no edge is created.
  • If I wrap the contents the second loop (for solid in section.Solids) in a try/except block, I get a segfault.
Since both of these problems are very likely dependent on my layout, I made it available at https://www.spida.net/tmp/freecad/box_part.fcstd
For reference, here is my "fixed" script:
import Part
#get the case
case = FreeCAD.ActiveDocument.getObjectsByLabel("Case")[0].Shape
shape =  FreeCAD.ActiveDocument.getObjectsByLabel("Scope")[0].Shape
#parameters
thickness = 10;  #thickness of foam
bbox = case.BoundBox
rightFace = case.Faces[2]
leftFace = case.Faces[3]
for x in range(0, int(bbox.XLength/thickness)):
   foam = Part.makeBox(thickness, bbox.YLength, bbox.ZLength);
   foam.translate(App.Vector(bbox.XMin + thickness*x, bbox.Center.y - foam.CenterOfMass.y, bbox.Center.z - foam.CenterOfMass.z));
   #we need to handle each solid separately
      projections = [];
      #find the left- and rightmost points in the outline and ensure that we have vertices there
      v1 = res[1];
      v2 = res[1];
      outline = res[0];
      e = [];
      if v2.Point.distanceToPoint(v2.Point) > 1e-4:
         e.append(Part.Edge(Part.Line(v1.Point, v1.Point + App.Vector(0, 0, bbox.ZLength))) );
         e.append(Part.Edge(Part.Line(v1.Point + App.Vector(0, 0, bbox.ZLength), v2.Point + App.Vector(0, 0, bbox.ZLength))) );
         e.append(Part.Edge(Part.Line(v2.Point + App.Vector(0, 0, bbox.ZLength), v2.Point)) );
         for edge in edges:
            if edge.Vertexes[0].Point.distanceToPoint(vertex.Point) < 1e-4:
               edges.remove(edge);
            if edge.Vertexes[1].Point.distanceToPoint(vertex.Point) < 1e-4:
               edges.remove(edge);
      if res:
         e.append(res[0]);
      while res and res[0] and res[1].Point.distanceToPoint(v1.Point) > 1e-4:
         if res:
            e.append(res[0]);
      #we are not sure we have build the real outer wire, we could have followed the wrong edge... brute force again!
   Part.show(foam)
Postby Kunda1 » Mon Jan 30, 2017 8:14 pm
ickby wrote:I had a stupid error in my script. I did not notive it yesterday as I don't run macros in a local environment... here a fixed version. As noted by deepsoic it does not work with occ7 as there are multiple differences. I think this is worth a bugreport and some investigation, at least the multifuse issue must be handled in FreeCAD, such differences should not be accepted.
import Part
#parameters
      projections = [];
      Part.show(solid)
      v1 = res[1];
      v2 = res[1];
      outline = res[0];
      e = [];
         for edge in edges:
               edges.remove(edge);
               edges.remove(edge);
      e.append(res[0]);
         e.append(res[0]);
   Part.show(foam)
Any headway on this issue #2676: Differences in python API depending on OCC version ?
DeepSOIC
Postby DeepSOIC » Mon Jan 30, 2017 8:49 pm
The documentation of OCC 7.1.0 still says the same, the output of face+face fusion is a compound of faces (and no shells).
https://www.opencascade.com/doc/occt-7. ... hms_9_4_12
AFAIK nothing was done on FreeCAD side to override this and bring back the old behavior yet.
