Displacement factor under 1?
pablogil
Postby pablogil » Wed Nov 09, 2016 9:28 am
I find sometimes that the Displacement minimum factor under "Results" task dialog, which is just 1, is too much to graphically show a small displacement... would it be possible to adjust the factor as, for instance, something like 0,001?
Thank you
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
bernd
Re: Displacement factor under 1?
Postby bernd » Wed Nov 09, 2016 1:59 pm
pablogil wrote:I find sometimes that the Displacement minimum factor under "Results" task dialog, which is just 1, is too much to graphically show a small displacement... would it be possible to adjust the factor as, for instance, something like 0,001?
By python easily …
- start FreeCAD
- Load Start WB
- Load 3D FEM example
- Activate analysis and run analysis
- run the following python code
mesh_obj = App.ActiveDocument.getObject("Box_Mesh")
result_obj =  App.ActiveDocument.getObject("CalculiX_static_results")
mesh_obj.ViewObject.setNodeDisplacementByVectors(result_obj.NodeNumbers, result_obj.DisplacementVectors)
mesh_obj.ViewObject.applyDisplacement(0.1)
by GUI, not at the moment ... I may have a look at this.
bernd
Postby bernd » Tue May 30, 2017 9:37 pm
more result scripting ...
# set stress color
mesh_obj.ViewObject.setNodeColorByScalars(result_obj.NodeNumbers, result_obj.StressValues)
# reset stress color
mesh_obj.ViewObject.NodeColor = {}
mesh_obj.ViewObject.ElementColor = {}
mesh_obj.ViewObject.setNodeColorByScalars()
bernd
Postby bernd » Fri Dec 14, 2018 6:43 am
small hint for the result scripting above ... use the result mesh not the analysis mesh. I may add the result scripting code to the wiki ...
